01-31-2009, 10:45 | #1 (permalink) |
Junior Member Join Date: Jan 2008
Member: 668980 Status: Offline Thanks Meter: 0 | HELP with my HUG Q-23 can't find with my pinfinder! |
01-31-2009, 13:46 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! lets start from checking what CPU it is based. you either can do this by disassembling phone or by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software |
01-31-2009, 14:40 | #3 (permalink) |
Member: 668980 Status: Offline Thanks Meter: 0 | hi! i dissambled the phone & here the details of cpu i think: MT62226BA 0726-BOAL CP3N91 is this supported to pinfinder? can you give me other option or pinout that can be detected by infinity box alone..thanks |
02-01-2009, 05:50 | #5 (permalink) |
Member: 668980 Status: Offline Thanks Meter: 0 | hi! it does'nt power from your pinfinder L12c connector.. but the status of the phone is phone lock code only,how does it is no detection at all and can't find the pinout? is this supported or find the pinout manually. tnx and more power infinity team! |
02-01-2009, 11:33 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! it doesnt must turn ON from L12c connector. this cable is only for Tx/Rx you must connect power "crocodiles" to battery terminals. have you done that? |
02-01-2009, 13:12 | #7 (permalink) |
Member: 668980 Status: Offline Thanks Meter: 0 | hi! i already tried the procedure u said,but still no pinout found from the pinfinder,what possible reason why this phone can't find the pinout? is there any manual pinout for this? thanks again.. |
02-01-2009, 13:24 | #8 (permalink) |
Cheater -Don't Deal with him- Join Date: Aug 2005 Location: /%%temp%%.;adb
Member: 172434 Status: Offline Sonork: 100.161280 Thanks Meter: 577 | hugo, i have unlocked a hugo having 18p connector, with my L18A cable, pinfinder didnt find phone, i opened and measured voltage, 12 rx 13 tx, then i entered that in pinfinder and it worked perfect. |
Can't find pinout with PinFinder for Anycool C9000 | loshh | Infinity-Box | 7 | 08-15-2008 11:13 |
