09-24-2010, 08:47 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: love me if you can
Member: 1150088 Status: Offline Sonork: ============ Thanks Meter: 254 | Help my LG kp 320 COM27 [VCP0] selected module v3.60 Device: LG-KP320 Checking data, wait... Action: write flash NAND write: Firmware KP320-00-V10a-ESA-XX-APR-17-2008_A7610_07A_PCB03_GPRS_MT6229_S02.7S7610AA00-001-R1A_En_Melayu_Indonesia_Vn_Th_Cn.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... converting data... done 0x01555800 bytes external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610AA00-001-R1A.bin nfi area detection (3 cores) finished: Ok "format ffs" active interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6229:8A02:8A02 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0014]: 0098:00F100900095 [TOSHIBA] TC58NVG0S3AFT chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NAND info... number of areas/bytes to read: 1:00080000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: header is empty: probably flash chip completely erased warning: can not detect header nfi area detection (0 cores) finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done nfi area detection... converting data... done 0x01555800 bytes external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610AA00-001-R1A.bin nfi area detection (3 cores) finished: Ok startup code area #1 check... done number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . . . . . write core... error: can not write flash: 0BEA:S_DA_NFB_BOOTLOADER_NOT_EXIST error: last error: 0BEA:S_DA_NFB_BOOTLOADER_NOT_EXIST Disconnect... done Finished, time used: 1 min 28 sec Remove/Install battery now ! BR hacell |
09-24-2010, 14:55 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, Try to flash phone with different flash files from support area. What is the results ? |
09-24-2010, 16:07 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, Hard to say for 100%, but if phone is completely dead and if it can not be flashed at all - it may be a HW problem with flash chip. |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
