12-31-2018, 14:09 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,104 | M2MT2 2.03 not openning solution here delete file named : FSCard.ini or just replace it with this FSCard.zip Last edited by rebainoor; 12-31-2018 at 14:15. |
The Following 10 Users Say Thank You to rebainoor For This Useful Post: |
12-31-2018, 15:12 | #3 (permalink) | |
The Following 10 Users Say Thank You to YellowBoss For This Useful Post: |
01-02-2019, 13:14 | #5 (permalink) | |
Freak Poster Join Date: Feb 2013 Location: ..::Gsm_zone::..
Member: 1888427 Status: Offline Sonork: 100.1619536 Thanks Meter: 163 | Quote:
My CM2 MT2 SOW THIS ERROR | |
01-02-2019, 13:24 | #6 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | It looks like your dongle support period is expired. How to check - https://www.infinity-box.com/doc/?r=17 If support is expired please contact to your seller and renew support - https://www.infinity-box.com/buy/ NOTE : CM2 MTK2 Require Your Smart Card Ver Is v0137 ..... |
01-02-2019, 16:15 | #9 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | your same problem means your dongle support period is expired. How to check - https://www.infinity-box.com/doc/?r=17 If support is expired please contact to your seller and renew support - https://www.infinity-box.com/buy/ |
01-12-2019, 10:43 | #12 (permalink) | |
Freak Poster Join Date: Apr 2013 Location: Pakistan Age: 24
Member: 1919988 Status: Offline Thanks Meter: 178 | plz help Quote:
here is pics | |
01-13-2019, 12:57 | #14 (permalink) | |
Freak Poster Join Date: Sep 2011 Location: Joined Infinity(dec2018)
Member: 1647864 Status: Offline Thanks Meter: 80 | Quote:
Code: === DongleManager [Infinity] v1.72 [1/13/2019 16:54:46] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0000############ Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): ######## Firmware version: 0137.02 === Process started: 1/13/2019 16:54:49 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today ! | |
01-13-2019, 13:50 | #15 (permalink) |
Member: 1647864 Status: Offline Thanks Meter: 80 | CM2MT2 not opening 100% working solution All users facing CM2MT2 not opening problem. Just Follow these simple steps to resolve your issue for always. 1. Un-install cm2mt2 from Control Panel >Programs 2. Install it in the C:\Program Files\CM2MT2 3. Open properties of cm2mt2.exe 4. Just check Run this program in compatibility mode for Windows XP (Service pack 3) and Run this program as an administrator For better Help and understanding see the following pictures carefully. |
