01-02-2009, 21:46 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: ALGERIA
Member: 447187 Status: Offline Thanks Meter: 107 | help N82 not format module v2.67 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... error: no any expected answer error: no any expected answer: wrong answer after chip id request error: no any expected answer error: no any expected answer: wrong answer after chip cfi request error: no any expected answer: wrong answer after chip id request number of flash chip/regions detected: 00/01 Unknown or damaged flash chip, operation aborted. Fault reasons: 1. damaged flash chip: replace or resolder/reball flash chip 2. damaged hardware: check hardware, water inside etc. 3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again 4. wrong model selection, try 'NAND' selection Initialize Fail Finished, time used: 43 sec Remove/Install battery now ! |
01-03-2009, 16:52 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! disable second pinout pins in advanced settings and then repeat pinout search this time pinfinder will skip this pins and will stop on First MCU pinout |
N82 meiye format done | GmmalGSM | Infinity-Box | 2 | 05-14-2009 23:29 |
help n328 not format & take flish not work | muhned | SpiderMan | 0 | 07-18-2008 15:59 |
ZTC N82 can't format | bachirDraria | Infinity-Box | 21 | 07-15-2008 20:40 |
N82 Successfull Formated | BOOTB | Infinity-Box | 2 | 05-08-2008 10:31 |
need help n82 after format phone dead | bilousoft | Chinese Cocktail | 1 | 12-27-2007 10:44 |
