06-09-2008, 18:11 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: SL3;HTC DesireHD DIRECT UNLOCk Age: 44
Member: 476287 Status: Offline Sonork: 100.1587961 Thanks Meter: 834 | help n95 after fomat not Powered On Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:B9C1:4B0E high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: A9EA80F098E59F:A9EA8000000000 flash: AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 damaged, recalculation required identification#1 detection finished device-id: E9F74320 identification#1 protocol ver: 04 ver. sw1: N618_PCB01_GPRS_MT6227_S01.BIN ver. sw2: N618.1, E5AB84DC ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[N618_PCB01_GPRS_MT6227_S01.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[N618_PCB01_GPRS_MT6227_S01.BIN]_20080609-174723.B0E.bin flash: EC257E25082501:29EA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: EC257E25082501:29EA0000000000 Finalization Done Finished, time used: 376 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
06-09-2008, 18:17 | #2 (permalink) |
Cheater -Don't Deal with him- Join Date: Aug 2005 Location: /%%temp%%.;adb
Member: 172434 Status: Offline Sonork: 100.161280 Thanks Meter: 577 | this is because software show u new firmware detected and u went on to press yes, just restore backup and all will be ok...... |
06-09-2008, 19:31 | #4 (permalink) |
Member: 476287 Status: Offline Sonork: 100.1587961 Thanks Meter: 834 | help what correct flash file for flashing the phone original eeprom eeprom[N618_PCB01_GPRS_MT6227_S01.BIN]_20080609-185424.B0E |
06-10-2008, 12:05 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! a log of firmwares "N618_PCB01_GPRS_MT6227_S01" in our support area. just use search button at the bottom of page. here is little example how to use "search" option: http://forum.gsmhosting.com/vbb/showthread.php?t=499453 |
n95 rm-159 not power on | rexxx | Nokia Hardware & Hardware Repair | 13 | 01-27-2010 13:23 |
Help me LG KE800 not power on after flach | adelgsm | FuriousGold | 1 | 11-18-2009 15:05 |
W810i after flashing not powering on | Nasmi | SonyEricsson (USB-Smart) | 4 | 08-08-2006 08:12 |
smart clip after update not powering on | fuzionGSM | Smart-Clip | 6 | 06-20-2005 22:04 |
t100 not power on after flash, not power on when original cable is plug | GYZMO | VLSI, Conexant, Skyworks and Old Models | 8 | 01-07-2004 00:34 |
