10-02-2010, 11:23 | #2 (permalink) |
No Life Poster Join Date: Sep 2006 Location: (¯Catch Me If U Can¯) Age: 50
Member: 360073 Status: Offline Thanks Meter: 2,181 | i think is wrong pinout !!!!!!!!!!!!!!!!! Code: COM3 [VCP1] selected module v3.22 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 2 sec Remove/Install battery now ! |
10-03-2010, 18:11 | #4 (permalink) |
Member: 360073 Status: Offline Thanks Meter: 2,181 | I did not pinfinder i have this error in more phone...; i think, i have prob in my infinity http://forum.gsmhosting.com/vbb/f425...ction-1102171/ http://forum.gsmhosting.com/vbb/f296...inout-1102015/ |
10-04-2010, 10:23 | #5 (permalink) | |
Please, explain what box problem you talk about, I want to understand it well. | |
10-04-2010, 20:08 | #6 (permalink) | |
Member: 360073 Status: Offline Thanks Meter: 2,181 | Quote:
http://forum.gsmhosting.com/vbb/f296...ml#post6409212 | |
10-05-2010, 18:16 | #7 (permalink) |
Member: 360073 Status: Offline Thanks Meter: 2,181 | Disassemble the phone and check PCB for the RX TX points.. If you not found a RX TX on PCB you have to check voltages on USB connecter for find the RX,TX. check this example. Explain to find pinout on 12 pin usb connector. 1. At first, you need to find GND signal (3pin-00.2v) 2. The second step: you need to find Tx Rx signals. Choose the pinouts, that may probably suit. You have 12 pinouts: 1pin-0.00v - this pinout is wrong 2pin-2.78 - it may correspond to Tx Rx signals 3pin-00.2v - GND signal 4pin-2.75v - it may correspond to Tx Rx signals 5pin-1.09v - LOOKS LIKE Tx Rx signals, BUT IT IS NOT! 6pin-0.00v - this pinout is wrong 7pin-4.02v - this pinout is wrong 8pin-2.89v - it may correspond to Tx Rx signals 9pin-3.05v - this pinout is wrong 10pin-0.00v - this pinout is wrong 11pin-1.09v - it may correspond to Tx Rx signals 12pin-0.02v - YOU DON'T NEED these fake signals with high and low voltage 3. In order to find Tx you need to put multimeter to test, diod ( "+" and "-" = beep ). When the phone is POWERED ON, Tx with GND make a sound beep. When it is TURNED OFF, it shows 600-700 ohm. It is suggested to do all the job using wire connection. After following the above mentioned steps you'll find, that 2pin is Tx and 8pin is Rx. Tx has to be 1.7v or 2.7v and Rx - 1.8v or 2.8v. These characteristics may change depending on the processor parameters. But Tx and Rx is not the same. Tx can be 2.78v, 2.75v, 2.7v. |
The Following 2 Users Say Thank You to MMDEBILI For This Useful Post: |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
