GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Infinity-Box (https://forum.gsmhosting.com/vbb/f296/)
-   -   Help needed to revive vodafone 541! (https://forum.gsmhosting.com/vbb/f296/help-needed-revive-vodafone-541-a-956381/)
JKKB 03-20-2010 02:21
Hello,
Can I get help from anyone with respect to one vodafone 541 that does not take any simcard after unlock? The set just blinks when a simcard is inserted.
Please,find below is the Log:COM9 [VCP0] selected
module v3.25
Device: Vodafone-541
Checking data, wait...
Action: rebuild security area
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:3903:A00E
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 01227E22302200:09EA0000000000
flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb
otp offset: 00000000
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is absent
startup code area #1 is damaged, recalculation required
rom info detection finished
device-id: B449745C
rom info ver: 07
sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN
project-id: MAUI.08A.W08.40.SP1.V32, A66F68AB
code offset: 00000000
ffs offset/size [01]: 01800000/00800000
TCL-ID is absent
ffs/eeprom address assigned: 01800000
startup code area #1 check...
Write: startup code area #1
startup code area #1 fixed
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
product id: JRDHUIZHOU_MT6225_OTMINI_SERIES
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
searching sec info#2...
search sec info#2 finished
sim-lock status: enabled
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#3...
search sec info#3 finished
area1 is valid
area2 is valid
area3 is valid
area4 is valid
number of sec info areas: 3
security area (sec info, part #2) calculation...
error: security area (sec info, part #2) header is invalid
security area (sec info, part #1) calculation...
..................security area (sec info, part #1) detecting size...
security area (sec info, part #1) detecting parameters...
security area (sec info, part #1) encoding...
done
Write: security area (sec info, part #1)
security area (sec info, part #1) calculation done
identification header detected
customization: XN17FB91
customization name adjusted
Write: security area (sec info, part #2)
security area (sec info, part #2) calculation done
done
done
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: 4D5DEDFD99A9C5
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Programme\InfinityBox\MModule\backup_security\V odafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_B449745C_AB686FA6_20100320-012222.B0X.bin
Finished, time used: 5 min 54 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Please, it is urgent.
Thanks in advance.:eek::rolleyes:
JKKB 03-20-2010 07:43
Originally Posted by JKKB (Post 5597332)
Hello,
module v3.25
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
status: 01
Boot Done
Initialize Done
====> Set baud ...
115200
Set baud Done
TCL-ID is absent
device-id: B449745C
rom info ver: 07
TCL-ID is absent
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
done
done
done
====> Write ...
Write Done
ffs formatting...
Finalization Done
PLEASE,INFINITY TEAM, I NEED YOUR HELP URGENTLY! THE DAMAGED HANDYS ARE 4 in NUMBER, NOT JUST 1!
InfinitySupport 03-20-2010 16:44
For newest Alcatel models (f.e. 203, 708, V541 etc.) that freez/reboot after sp-unlock:
1. use "MModule" software v3.22 or newer
2. use "Write" button from software "Service" page and write original imei (from phone back label)
3. make "sp-unlock"
JKKB 03-20-2010 20:13
2. use "Write" button from software "Service" page and COM9 [VCP0] selected
module v3.25
Action: "repair imei"
new imei: 359081034166451
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001:B803:A005
status: 01
Boot Done
Initialize Done
====> Set baud ...
115200
Set baud Done
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: C:\Programme\InfinityBox\MModule\backup_security\i d.4E5380C9.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_AB686FA6].rpl
device-id: 4E5380C9
rom info ver: 07
TCL-ID is absent
area1 is valid
area2 is invalid
area3 is valid
area4 is invalid
sim-lock status: disabled
area1 is valid
area2 is valid
area3 is valid
area4 is valid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
original imei: 35908103416645
pass #1
firmware remap[03]: 08000000
pass #2
====> Write ...
Write: imei
Write: imei
sec info (fast) detection...
done
relocation table detected
name table detected
customization: SN17G140
error: customization name is unknown
error: can't read customization version
error: can't calculate security area (sec info, part #2), existing data will be used
Check support area for updates !
done
name table detected
done
Write Done
ffs formatting...
Finalization Done
file saved: C:\Programme\InfinityBox\MModule\backup_security\V odafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_4E5380C9_AB686FA6_20100320-200614.B0X.bin
Finished, time used: 6 min 51 sec
I used MModule Software Version 3.25.
Please I need your help.
Thanks in advance.
3. make "sp-unlock"
Hello Mr Infinity Support,
Thanks very much for the quick answer. I tried to write the correct IMEI on one of the Handys,but the process still fails, software saying:
sec info,part#2
cannot be read.
Please see the attached LOG:
YellowBoss 03-20-2010 21:45
Hello,
Try to flash phone with any 541 firmware from support area and then repeat unlock operation once again.
Hello,
JKKB 03-20-2010 22:32
Originally Posted by YellowBoss (Post 5601493)
Hello,
Hi,
Thanks for the answer. I checked from support under Vodafone 541 and the page says I should check for Flashfiles under ALCATEL 708.
Over there, I find flashfiles similar to the firmwares in Vodafone 541.
I chose one Flashfile beginning with this:708x-2EVDPT-117B-XN17FG72-JRDSZ225---------.
I could not get Language/Customization Pack as well as EEPROM FILES,so I chose the only available ALCATEL 708 EEEPROM File.
I flashed 1 of the Handsets with these Files and the result is a dead PHONE!
Please, which files should I choose!___ I mean,should I choose only Firmware File or both Firmware + Customization/Language Packs?
Please your guidelines will be greatly appreciated.
Best Regards.
YellowBoss 03-20-2010 23:05
You have to use just one firmware file.
You do not need to use any kind of customization.language or eeprom files.
Now use any firmware file, make "Format ffs during write" box checked and flash phone.
JKKB 03-21-2010 00:20
Hellow Dear Mr Yellow Boss,
THanks for the guidelines.Still after trying with the "DEAD" phone,it cannot be revived.I was getting error messages during the Flash Process:Just take a glance at the attached Logs.
"Security area part #2 cannot be calculated and existing data will be used and that I should check Support Area for Updates."
But it seems I am using the latest Software from Support.
Your help will be much appreciated.
Best Regards.
LOGS:
COM9 selected
module v3.25
Action: write flash
"smart write" active
"format ffs" active
write: Firmware
708X-2CTBNL1-16B_XN16CQ24_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAU I_08A_W08_40_SP1_V32_2009-08-10_En_Nl_Fr_De_Tr.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
enhanced security fix enabled
====> Boot ...
baud autodetection active
19200 autodetect
Connecting, wait...
CPU: MT6225
chip: 0001:5B03:A003
status: 01
Boot Done
Initialize Done
====> Set baud ...
460800
Set baud Done
TCL-ID is absent
device-id: B98F6F30
rom info ver: 07
project-id: MAUI.08A.W08.40.SP1.V32, DA91E590
TCL-ID is absent
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
security area (sec info, part #1) size is incorrect: ED16F000
area1 is invalid
area2 is valid
area3 is valid
area4 is invalid
area1 is invalid
area2 is valid
area3 is valid
area4 is invalid
original imei: 35908103406914
====> Write ...
usb bootloader (file) is present: 00020000
rom info relocation detected
startup code area #1 calculation...
file saved: C:\Programme\InfinityBox\MModule\backup_security\V odafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_B98F6F30_90E591DA_20100320-234118.B0X.bin
Area: Firmware
Write: Firmware
..................region counter set: 01
done
name table detected
customization: SN16B130
done
name table detected
done
Write Done
ffs formatting...
Finalization Done
file saved: C:\Programme\InfinityBox\MModule\backup_security\V odafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_B98F6F30_90E591DA_20100320-235949.B0X.bin
Finished, time used: 19 min 42 sec
YellowBoss 03-21-2010 09:58
Hello,
Try to use another firmware from support area and flash phone again.
This phone can be repaired in any case, it's impossible to kill it permanently.
Flash phone once again now and post log here.
JKKB 03-21-2010 10:17
Originally Posted by YellowBoss (Post 5603023)
Hello,
Hellow Mr Yellow Boss,
I do appreciate your efforts.Thanks once again. I will keep on trying as you have suggested.
Meanwhile,I am reading FULLFLASH and sending them to :[email protected]
I hope to keep you informed of latest developments.
Best Regards.
JKKB 03-21-2010 12:32
Help, infinity team,mmodule killing vodafone 541 handsets!
Dear Infinity Team, The other day I tried to unlock Vodafone 541, 4 resulted in being damaged. Today i tried to flash one of them and the result is a DEAD phone!
Please,see the attached LOGS:
COM9 selected
module v3.25
Action: write flash
"format ffs" active
write: Firmware
708X-2EVDPT1-117B_XN17FG72_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MA UI_08A_W08_40_SP1_V32_2009-09-10_En_Fr_Es_De_Pt_Vodafone-541.B0M.bin
skip: Customization
skip: Eeprom/ffs
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001:D903:A00F
status: 01
Boot Done
Initialize Done
====> Set baud ...
460800
Set baud Done
TCL-ID is absent
startup code area #1 backup saved: C:\Programme\InfinityBox\MModule\backup_security\i d.C60590C4.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_AB686FA6].rpl
device-id: C60590C4
rom info ver: 07
TCL-ID is absent
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
area1 is invalid
area2 is valid
area3 is valid
area4 is valid
area1 is invalid
area2 is valid
area3 is valid
area4 is valid
original imei: 35908103416686
====> Write ...
file saved: C:\Programme\InfinityBox\MModule\backup_security\V odafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_C60590C4_AB686FA6_20100321-120333.B0X.bin
Area: Firmware
Write: Firmware
done
name table detected
customization: SN17B140
done
name table detected
done
Write Done
ffs formatting...
Finalization Done
file saved: C:\Programme\InfinityBox\MModule\backup_security\V odafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_C60590C4_AB686FA6_20100321-122229.B0X.bin
Finished, time used: 20 min 8 sec
Please, I need your help!
Thanks in advance.:eek:;)
YellowBoss 03-21-2010 13:06
What was the reason to start new thread instead of continue discussion in previous thread (threads merged) ?
JKKB 03-21-2010 13:21
Originally Posted by YellowBoss (Post 5603656)
What was the reason to start new thread instead of continue discussion in previous thread ?
Dear Sir,
Please excuse me if I have made a mistake. The reason is that I have flashed another phone with the result that the phone cannot power on. Since this particular phone is not the one I started the thread earlier with,I thought I needed to start this new thread to highlight the problems therein.
Now I have seen that updates have been made to the MModule.Right now I am trying to reflash this second "DEAD" phone with the latest Flashfile from Support and the Latest Software Module3.26.
I hope to notify you of results.
Thanks in advance.
JKKB 03-21-2010 14:01
Originally Posted by JKKB (Post 5603708)
Dear Sir,
Thanks in advance.
I tried with Latest MModule and latest Flashfile from support,but still, the set can't power on!
Here the LOGS:
COM9 selected
module v3.26
Action: write flash
"format ffs" active
write: Firmware
708X-2CRGGB1-169_XN16CC25_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAU I_08A_W08_40_SP1_V32_2009-08-05_En_Fr_Es_It_De.B0M.bin
skip: Customization
skip: Eeprom/ffs
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
status: 01
Boot Done
Initialize Done
====> Set baud ...
460800
Set baud Done
TCL-ID is absent
device-id: C60590C4
rom info ver: 07
project-id: MAUI.08A.W08.40.SP1.V32, A050F4E8
TCL-ID is absent
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
area1 is invalid
area2 is valid
area3 is valid
area4 is valid
area1 is invalid
area2 is valid
area3 is valid
area4 is valid
====> Write ...
file saved: C:\Programme\InfinityBox\MModule\backup_security\V odafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_C60590C4_E8F450A0_20100321-130617.B0X.bin
Area: Firmware
Write: Firmware
done
name table detected
customization: SN169050
done
name table detected
done
Write Done
ffs formatting...
Finalization Done
file saved: C:\Programme\InfinityBox\MModule\backup_security\V odafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_C60590C4_E8F450A0_20100321-132756.B0X.bin
Finished, time used: 22 min 57 sec
Please may I know the reasons for the red quoted errors?
Best Regards.
JKKB
Page generated in 0.39300 seconds with 6 queries
