03-21-2010, 14:16 | #16 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Please, try to use this new software and flash phone again: http://www.infinity-box.com/download...e_v3.27_v1.rar Waiting for your results, post here operation log. |
03-21-2010, 14:47 | #17 (permalink) | |
Freak Poster Join Date: Jul 2007
Member: 548443 Status: Offline Thanks Meter: 70 | Quote:
I have tried to install this Software in the MModule, but still I get Module Software Version 3.26 instead of 3.27. I used the 3.26 to reflash,but still the same results: LOGS: COM9 selected module v3.26 Device: Vodafone-541 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active "format ffs" active write: Firmware 708X-2CRGGB1-169_XN16CC25_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAU I_08A_W08_40_SP1_V32_2009-08-05_En_Fr_Es_It_De.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001903:A00F status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22302200:09EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Programme\InfinityBox\MModule\backup_security\i d.C60590C4.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_FC4F51B9].rpl rom info detection finished device-id: C60590C4 rom info ver: 07 sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN project-id: MAUI.08A.W08.40.SP1.V32, B9514FFC code offset: 00020000 ffs offset/size [01]: 01800000/00800000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ffs/eeprom address assigned: 01800000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35908103416686 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... usb bootloader (file) is present: 00020000 rom info relocation detected startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed file saved: C:\Programme\InfinityBox\MModule\backup_security\V odafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_C60590C4_FC4F51B9_20100321-143735.B0X.bin Area: Firmware flash: 01227E22302200:09EA0000000000 Write: Firmware sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... search sec info#2 finished searching sec info#3... search sec info#3 finished number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 01227E22302200:09EA0000000000 flash: 01227E22302200:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected relocation table detected name table detected customization: SN169050 error: customization name is unknown error: can't read customization version error: can't calculate security area (sec info, part #2), existing data will be used Check support area for updates ! security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 01227E22302200:09EA0000000000 flash: 01227E22302200:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected relocation table detected name table detected customization: SN169050 error: customization name is unknown error: can't read customization version error: can't calculate security area (sec info, part #2), existing data will be used Check support area for updates ! security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 01227E22302200:09EA0000000000 flash: 01227E22302200:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Write Done ====> Finalization ... ffs formatting... flash: 01227E22302200:09EA0000000000 Finalization Done file saved: C:\Programme\InfinityBox\MModule\backup_security\V odafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_C60590C4_FC4F51B9_20100321-144148.B0X.bin Finished, time used: 5 min 31 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! I am still waiting for your guidelines. | |
03-21-2010, 14:59 | #18 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hi, read full flash from this phone and send full flash backup (or link) to [email protected] to check. |
03-21-2010, 15:39 | #19 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, It was need to see what was inside phone flash chip after last flash write attempt, so your old files was useless. Anyway, try to use this new software and flash phone again: http://www.infinity-box.com/download...e_v3.27_v2.rar Waiting for your results, post here operation log. |
03-21-2010, 15:48 | #20 (permalink) | |
This morning, I read full flash of the 4 Handys with their respective IMEIs to [email protected] I hope by now,the Team has received them. I uploaded the Files at Rapidshare.com Best Regards. | |
03-21-2010, 15:58 | #21 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, It was need to see what was inside phone flash chip after last flash write attempt, so your old files (that was read at morning) was useless. Anyway, try to use this new software and flash phone again (do not read flash, just try to write flash once again with new software): http://www.infinity-box.com/download...e_v3.27_v2.rar Waiting for your results, post here operation log. |
03-21-2010, 16:14 | #22 (permalink) | |
The new software has been extracted to MModule successfully and now I have used Version 3.27 to flash the phone, but very unfoCOM9 selected module v3.27 Device: Vodafone-541 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active "format ffs" active write: Firmware 708X-2CRGGB1-169_XN16CC25_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAU I_08A_W08_40_SP1_V32_2009-08-05_En_Fr_Es_It_De.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001903:A00F status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22302200:09EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Programme\InfinityBox\MModule\backup_security\i d.C60590C4.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_FC4F51B9].rpl rom info detection finished device-id: C60590C4 rom info ver: 07 sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN project-id: MAUI.08A.W08.40.SP1.V32, B9514FFC code offset: 00020000 ffs offset/size [01]: 01800000/00800000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ffs/eeprom address assigned: 01800000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35908103416686 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... usb bootloader (file) is present: 00020000 rom info relocation detected startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed file saved: C:\Programme\InfinityBox\MModule\backup_security\V odafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_C60590C4_FC4F51B9_20100321-155918.B0X.bin Area: Firmware flash: 01227E22302200:09EA0000000000 Write: Firmware sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... search sec info#2 finished searching sec info#3... search sec info#3 finished number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 01227E22302200:09EA0000000000 flash: 01227E22302200:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected relocation table detected name table[00] #9000000 detected customization: SN169050 error: customization name is unknown name table[01] #7000000 detected customization: CN16CC25 customization name adjusted customization: CN16CC25 customization name adjusted customization detected: CN16CC25 customization: CN16CC25 flash: 01227E22302200:09EA0000000000 flash: 01227E22302200:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 01227E22302200:09EA0000000000 flash: 01227E22302200:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected relocation table detected name table[00] #9000000 detected customization: SN169050 error: customization name is unknown name table[01] #7000000 detected customization: CN16CC25 customization name adjusted customization: CN16CC25 customization name adjusted customization detected: CN16CC25 customization: CN16CC25 flash: 01227E22302200:09EA0000000000 flash: 01227E22302200:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 01227E22302200:09EA0000000000 flash: 01227E22302200:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Write Done ====> Finalization ... ffs formatting... flash: 01227E22302200:09EA0000000000 Finalization Done file saved: C:\Programme\InfinityBox\MModule\backup_security\V odafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_C60590C4_FC4F51B9_20100321-160329.B0X.bin Finished, time used: 5 min 34 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! rtunately,the phone still does not power on. Please find attached is the LOG: Please,I am eagerly awaiting your suggestions. Best Regards. | |
03-21-2010, 16:35 | #23 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Are you sure that phone can not power-on now ? Did you checked battery voltage ? Did you tried to press and hold phone "power" button for a long time ? |
03-21-2010, 16:58 | #24 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | If phone still can not power-on well (but I think that it should be alive) - try to make "Repair security area" operation and post log here so I'll check it. |
03-21-2010, 17:03 | #25 (permalink) | |
Yes, the phone cannot power on. I recharged battery with one of the rest funtioning handsets and the battery is fully charged. I pressed and held the power button for a very long time,not less than 5 minutes,but still the set does not power on. Best Regards. JKKB. | |
03-21-2010, 17:12 | #26 (permalink) | |
Please find attached below is the "SECURITY AREA REPAIR" Logs. COM9 selected module v3.27 Device: Vodafone-541 Checking data, wait... advanced flash detection enabled Action: repair security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001903:A00F status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22302200:09EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Programme\InfinityBox\MModule\backup_security\i d.C60590C4.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_FC4F51B9].rpl rom info detection finished device-id: C60590C4 rom info ver: 07 sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN project-id: MAUI.08A.W08.40.SP1.V32, B9514FFC code offset: 00020000 ffs offset/size [01]: 01800000/00800000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... search sec info#2 finished searching sec info#3... search sec info#3 finished number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 01227E22302200:09EA0000000000 flash: 01227E22302200:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected relocation table detected name table[00] #9000000 detected customization: SN169050 error: customization name is unknown name table[01] #7000000 detected customization: CN16CC25 customization name adjusted customization: CN16CC25 customization name adjusted customization detected: CN16CC25 customization: CN16CC25 flash: 01227E22302200:09EA0000000000 flash: 01227E22302200:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 01227E22302200:09EA0000000000 flash: 01227E22302200:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected relocation table detected name table[00] #9000000 detected customization: SN169050 error: customization name is unknown name table[01] #7000000 detected customization: CN16CC25 customization name adjusted customization: CN16CC25 customization name adjusted customization detected: CN16CC25 customization: CN16CC25 flash: 01227E22302200:09EA0000000000 flash: 01227E22302200:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 01227E22302200:09EA0000000000 flash: 01227E22302200:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35908103416686 flash: 01227E22302200:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E22302200:09EA0000000000 Finalization Done file saved: C:\Programme\InfinityBox\MModule\backup_security\V odafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_C60590C4_FC4F51B9_20100321-170812.B0X.bin Finished, time used: 3 min 29 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Best Regards. | |
03-21-2010, 18:03 | #28 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | @JKKB Flash phone with this firmware: 708X-2CALRU1-16E_XN16BN24_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAU I_08A_W08_40_SP1_V32_2009-08-28_En_Fr_De_Ru_Ua_simfree_v2.B0M.bin What is the results ? |
03-21-2010, 19:08 | #29 (permalink) | |
Please find below is the operation LOG: COM9 selected module v3.27 Device: Vodafone-541 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active "format ffs" active write: Firmware 708X-2CALRU1-16E_XN16BN24_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAU I_08A_W08_40_SP1_V32_2009-08-28_En_Fr_De_Ru_Ua_simfree.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001903:A00F status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22302200:09EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Programme\InfinityBox\MModule\backup_security\i d.C60590C4.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_FC4F51B9].rpl rom info detection finished device-id: C60590C4 rom info ver: 07 sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN project-id: MAUI.08A.W08.40.SP1.V32, B9514FFC code offset: 00020000 ffs offset/size [01]: 01800000/00800000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ffs/eeprom address assigned: 01800000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35908103416686 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... usb bootloader (file) is present: 00020000 rom info relocation detected startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed file saved: C:\Programme\InfinityBox\MModule\backup_security\V odafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_C60590C4_FC4F51B9_20100321-182619.B0X.bin Area: Firmware flash: 01227E22302200:09EA0000000000 Write: Firmware sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... search sec info#2 finished searching sec info#3... search sec info#3 finished number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 01227E22302200:09EA0000000000 flash: 01227E22302200:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected relocation table detected name table[00] #9000000 detected customization: SN16E050 error: customization name is unknown name table[01] #7000000 detected customization: CN16BN24 customization name adjusted customization: CN16BN24 customization name adjusted customization detected: CN16BN24 customization: CN16BN24 flash: 01227E22302200:09EA0000000000 flash: 01227E22302200:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 01227E22302200:09EA0000000000 flash: 01227E22302200:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected relocation table detected name table[00] #9000000 detected customization: SN16E050 error: customization name is unknown name table[01] #7000000 detected customization: CN16BN24 customization name adjusted customization: CN16BN24 customization name adjusted customization detected: CN16BN24 customization: CN16BN24 flash: 01227E22302200:09EA0000000000 flash: 01227E22302200:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 01227E22302200:09EA0000000000 flash: 01227E22302200:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Write Done ====> Finalization ... ffs formatting... flash: 01227E22302200:09EA0000000000 Finalization Done file saved: C:\Programme\InfinityBox\MModule\backup_security\V odafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_C60590C4_FC4F51B9_20100321-185344.B0X.bin Finished, time used: 28 min 43 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Please I need your further advice; now 2 handsets are "dead" through flashing; the other 2 have Sim ,power on/off problems after unlock. I just don't know why. Please try your best to help me solve these problems. Thanks in advance. JKKB | |
problem to revive vodafone 226FM. | manistar | FuriousGold | 0 | 01-15-2009 13:36 |
Need Help to Revive Vodafone 226FM | ~Gsm_Solutions~ | FuriousGold | 3 | 11-28-2008 14:47 |
help needed to revive my u600 | blu260601 | Samsung Hardware Repair | 0 | 11-09-2008 01:06 |
Need to revive a dead V60 Help | ciavatta | Motorola P2k | 7 | 09-11-2006 09:47 |
Flash V60i Need to revive please HELP!!! | venomhotboy | Smart-Clip | 7 | 11-26-2005 10:40 |
