03-21-2010, 20:06 | #31 (permalink) | |
Freak Poster Join Date: Jul 2007
Member: 548443 Status: Offline Thanks Meter: 70 | Quote:
At the beginning of the thread, I mentioned that I unlocked 15 pieces of these Vodafone 541: 11(eleven) of them were very successful. The rest 4 pieces got the following problems: When I power on the phones,they will start normally.But when I try to make emergency calls,they will shut down for some short time, about 10 seconds and will power on again and back to menu display, this occurs when no SIMCARD is inserted. When I power on the handsets and put in any Simcard, the sets will power off and on showing only white displays. Out these 4,I tried to flash 2 and both are"DEAD" now, remaining the other 2. Please,your help is needed. Thanks. | |
03-21-2010, 20:33 | #32 (permalink) | |
Please, read more here: Can not make a call - Infinity-Box As about phones that can not power-on at all. It may be hardware problem too, due to I can not imagine what may be wrong with this type of phone (especially after you have tried to flash it with "simfree" firmware that I told you, this firmware was tested with many different phones and it was found no problems). As I can see from operation log, software can not read from your "dead" phones "TCL-ID" identification (special area with software version etc). This problem reason may be a damaged (partially) flash chip or bad soldered flash chip, so I suggest you to open phone, rehot/reball flash chip and try to flash it again. | |
03-21-2010, 22:08 | #33 (permalink) | |
Thanks for your efforts. Please,may I know the meaning of "TCL-ID" absent? I just wonder why 4 pieces out of just 15 handys could be with hardware problems! By the way, I will keep on following your recommendation. I hope to notify you of any developments. Meanwhile, I have performed Phone detailed Information procedure and found out that both damaged and working handys have TCL-ID absent in them. Best Regards. | |
03-22-2010, 10:48 | #35 (permalink) | ||
But I am completely sure that unlock attempt can not affect to network signal level, so if your phone can not make 112/emergency call - you have to repair hardware. I can tell something about this only after I'll see your phone flash chip content (that was read not days ago, but after last flash write attempt). | ||
03-23-2010, 17:08 | #36 (permalink) |
Member: 548443 Status: Offline Thanks Meter: 70 | PLease Look at this Brand New Vodafone541 Information Log and comment on "TCL-ID" Dear Infinity TEam, I have just bought 2 Brand New Vodafone 541. Both are functioning okay and I have not tried to either unlock or flash both. I have just performed" READ DETAILED INFORMATION" procedure and discovered that "TCL-ID absent" is inside this Log. A similar operational LOG is found with the "DAMAGED" Phones. What I do not understand is that why should "TCL-ID" be absent when the Set is functioning good? Please,I need your comments on this issue. Find below is the "Information Operational" Log: COM9 selected module v3.27 Device: Vodafone-541 Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:1603:A009 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000003:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Programme\InfinityBox\MModule\backup_security\i d.A7C45286.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_E8F450A0].rpl rom info detection finished device-id: A7C45286 rom info ver: 07 sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN project-id: MAUI.08A.W08.40.SP1.V32, A050F4E8 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ffs/eeprom address assigned: 01800000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 detecting firmware version... firmware version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN detecting firmware build... ........................................ firmware build: %lMAUI.08A.W08.40.SP1.V32JRDSZ25_08A_HW2009-09-1010-56 detecting product-id... .................................................. .................................................. ............................ done detecting languages... .................................................. ...................... language parameters detected detected languages: En Nl Fr De Tr original imei: 35400703077277 file saved: C:\Programme\InfinityBox\MModule\backup_security\V odafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_A7C45286_E8F450A0_20100323-164939.B0X.bin Finished, time used: 2 min 11 sec Remove/Install battery now ! Best Regards. JKKB |
03-24-2010, 00:19 | #37 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, As about TCL-ID area: we will double check why it can not be read from good working phone. Did you checked your phones hardware ?\I am quite interested to know what was happened with phones that can not make 112/emergency call. Last edited by YellowBoss; 03-24-2010 at 00:32. |
03-24-2010, 20:19 | #38 (permalink) |
Freak Poster Join Date: Jun 2008 Location: Egypt
Member: 801293 Status: Offline Sonork: 100.1581561 Thanks Meter: 170 | Thanks Infinity team Today I have been unlock Vodafone 541 without any problems just use ( module v3.28 ) and press SP-unlock here is log : COM25 [VCP1] selected module v3.28 Device: Vodafone-541 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:F803:A00F status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000003:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.8BA00 B2E.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_E8F450A0].rpl rom info detection finished device-id: 8BA00B2E rom info ver: 07 sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN project-id: MAUI.08A.W08.40.SP1.V32, A050F4E8 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN17FC75 customization name adjusted flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN17FC75 customization name adjusted flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35400703165392 flash: 98006F00000003:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000003:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_8BA00B2E_E8F450A0_20100324-204602.B0X.bin Finished, time used: 5 min 46 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Thanks Infinity team Regards KOKO_TARGET |
The Following User Says Thank You to U.F.O. For This Useful Post: |
03-27-2010, 08:57 | #39 (permalink) | |
I warmed up the flashchip and tried to flash again,but still,the problems exist. I am continuosly searching for solutions. Whatever I finally achieve,I will notify you. Meanwhile, why does "TCL.ABSENT" continue to show in both functioning and damaged phones? Best Regards. | |
03-28-2010, 17:32 | #40 (permalink) | |
Hello, We will remove text "TCL absent" in new MModule software release to avoid user's misunderstanding. Please, check other threads and you will see, that any 708/541 phone can be 100% repaired with Infinity-Box (in case of working hardware). | |
04-07-2010, 14:37 | #41 (permalink) | |
Finally I have been able to revive the 4 Handsets and got them working without problems. The problems were more of software than hardware. I flashed the 4 with an unbranded simlock-free flashfile with another tool and all 4 could and now function alright. I just keep wondering and asking myself why 4 out of the 15 handsets(all 15 handsets with the same firmware) could pose such problems! Thank you very much for the help you rendered me and I think you can now close this thread,unless you need ,maybe,another information from me. Once again,thank you very much. JKKB | |
04-07-2010, 15:36 | #42 (permalink) | |
No Life Poster Join Date: Feb 2004 Location: @Work
Member: 56215 Status: Offline Thanks Meter: 67 | Quote:
is realy strange, i flashed,Repair many V541 without problems. Had to repair no power on and other from Customers Experiments. And i solved all by Infinity. Br | |
problem to revive vodafone 226FM. | manistar | FuriousGold | 0 | 01-15-2009 13:36 |
Need Help to Revive Vodafone 226FM | ~Gsm_Solutions~ | FuriousGold | 3 | 11-28-2008 14:47 |
help needed to revive my u600 | blu260601 | Samsung Hardware Repair | 0 | 11-09-2008 01:06 |
Need to revive a dead V60 Help | ciavatta | Motorola P2k | 7 | 09-11-2006 09:47 |
Flash V60i Need to revive please HELP!!! | venomhotboy | Smart-Clip | 7 | 11-26-2005 10:40 |
