06-07-2016, 07:31 | #1 (permalink) | |||
No Life Poster Join Date: Apr 2007 Location: (¯_PAKISTAN_¯)
Member: 491455 Status: Offline Sonork: On My LAB Thanks Meter: 296 | Help Needed for SPD Quote:
06-07-2016, 14:30 | #3 (permalink) |
Member: 491455 Status: Offline Sonork: On My LAB Thanks Meter: 296 | in normal LDR 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 57 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! |
06-08-2016, 06:11 | #6 (permalink) |
Member: 491455 Status: Offline Sonork: On My LAB Thanks Meter: 296 | Done Thanks 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 72 ] Port Opened Sync... InitSvc Done Wait for phone... Sync... Init Ok , reset settings ... Format Ok! Done |
06-08-2016, 09:24 | #8 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Yes, Reset and read info works in SVC mode irrespective of cpu selection in. But for other operation you will need to select correct cpu with loader to pass structure detection by software. Br. Infinity Box Support Team. |
