07-30-2011, 14:31 | #1 (permalink) |
Freak Poster Join Date: Jan 2008 Location: Indonesian Age: 37
Member: 672242 Status: Offline Sonork: 100.1640826 Thanks Meter: 23 | Help, nexian S868 dead after flash I have a case nokia S868 MT6235 open a message only loading. I first read, keep in a tab format FFS FFS results ok but ask for touchscreen calibration, ok my calibration results can enter the menu but the touchscreen does not work. I flash back to the last backup, the results are dead phone. These logs: Code: COM5 [VCP0] selected module v3.96 Device: Autodetect 6228-6253 NAND Checking data, wait... Action: write flash NAND write: Firmware TINNO35_09A_PCB01_GPRS_MT6235B_S01.E930-03A_W09_34_F13_MP_INDO_V15__firmware_20110730-170820.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E930-03A_W09_34_F13_MP_INDO_ nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8C00:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[001E]: 0020:007600200076 [ST] ST512W3A chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done interesting cpu type found: 6235:8C00:8A00 ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: E930-03A_W09_34_F13_MP_INDO_V15 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E930-03A_W09_34_F13_MP_INDO_ nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... error: unexpected answer: startup code area #1 is invalid startup code area #1 detection done rom info ver: 07 sw version: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E930-03A_W09_34_F13_MP_INDO_V15.BIN project-id: E930-03A_W09_34_F13_MP_INDO_V15, 47945203 code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ===> done nfi area detection... bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E930-03A_W09_34_F13_MP_INDO_ nfi area detection (3 cores) finished: Ok startup code area #1 check... rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.00006235.[TINNO35_09A_PCB01_GPRS_MT6235B_S01.E930-03A_W09_34_F13_MP_INDO_V15.BIN_03529447].rpl rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.00006235._TINNO35_09A_PCB01_GPRS_MT6235B_S01.E930-03A_W09_34_F13_MP_INDO_V15.BIN_03529447_.rpl rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.00006235.[TINNO35_09A_PCB01_GPRS_MT6235B_S01.E930-03A_W09_34_F13_MP_INDO_V15.BIN_03529447].rpl rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.00006235._TINNO35_09A_PCB01_GPRS_MT6235B_S01.E930-03A_W09_34_F13_MP_INDO_V15.BIN_03529447_.rpl ==================== warning: unknown firmware: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E930-03A_W09_34_F13_MP_INDO_V15.BIN_03529447 Unknown firmware found (v.3.26, database date: 21.06.2011), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E930-03A_W09_34_F13_MP_INDO_V15.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed You can flash phone now but can not finalize it, in most cases phone CAN NOT power-on. Do you want to continue anyway ? number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . write core... Disconnect... done Finished, time used: 8 min 21 sec Remove/Install battery now ! please solve my case. thx B4 B.R Patrick |
07-31-2011, 10:53 | #2 (permalink) |
Member: 672242 Status: Offline Sonork: 100.1640826 Thanks Meter: 23 | Dear Infinity Team: I'm sorry, I'm mistake with the phone type: correct NEXIAN G868 Up...Up...Up.... Hellooo, everybody anyone can help my problem... B.R Patrick |
08-01-2011, 11:45 | #3 (permalink) |
Member: 672242 Status: Offline Sonork: 100.1640826 Thanks Meter: 23 | Hello Infinity TEaM: This Is Type Firmware: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E930-03A_W09_34_F13_MP_INDO_V15 this is the file backup results to the case of loading only the message: Download NEXIAN_G868_MT6235_V15.rar and this file is OK to read from new phone: Download NEXIAN_G868_MT6235_V15_OK.rar but write them into my phone the phone still dead B.R Patrick |
08-02-2011, 14:56 | #4 (permalink) |
Junior Member Join Date: Nov 2008 Location: " West Java - South Borneo "
Member: 892586 Status: Offline Thanks Meter: 11 | MT6235B, me too .. dead after flash ...! what is this...: error: # 1 startup code area can not be fixed You can flash phone now but can not Finalize it, in most cases CAN NOT phone power-on. Do you want to continue anyway? I have flash with similar files from a normal fixed telephone warnings like that what wrong...? please help... |
