11-24-2007, 08:07 | #1 (permalink) |
Freak Poster Join Date: Sep 2006 Location: Indonesia
Member: 355635 Status: Offline Thanks Meter: 53 | help PAN X300 unlock cable is ok coz if i try to reset software can boot .... see the log when i try to unlock ==== log opened: [11/24/2007 1:53:20 PM] ==== Application: C:\Program Files\InfinityBox\QModule\QModule.exe Loading data, wait... [Infinity Box] v2.20 S/N: 2143:010C Wait... Current device: Panasonic-X300 Done COM6 [VCP0] selected Device: Panasonic-X300 Checking data, wait... Action: Unlock Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! error: wrong answer, errorcode#37 Boot Fail error: Finished Remove/Install battery now ! Time used: 16 sec COM6 [VCP0] selected Device: Panasonic-X300 Checking data, wait... Action: Unlock Boot... Press and HOLD Power button ! Connecting, wait... error: boot failed: 3D Release Power button ! error: wrong answer, errorcode#37 Boot Fail error: Finished Remove/Install battery now ! Time used: 41 sec COM6 [VCP0] selected Device: Panasonic-X300 Checking data, wait... Action: Unlock Boot... Press and HOLD Power button ! error: wrong answer, errorcode#37 Boot Fail error: wrong answer[64] Finished Remove/Install battery now ! Time used: 29 sec ---------------------------------------------------------- and this log when i try to reset ---------------------------------------------------------- COM6 [VCP0] selected Device: Panasonic-X300 Checking data, wait... Action: Reset Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 98007400000012:98E59F00000000 flash: Toshiba 50VSF5782 T 8Mb id: 00005279 Boot Done Set baud... 115200 Set baud Done Check Flash... Check Flash Done Check space... Check space Done Check parameters... Check parameters Done Format file system... area-01... area requested/selected: 02/02 area-02... area requested/selected: 02/02 Format file system Done Write... Write Done Finished Remove/Install battery now ! Time used: 27 sec please help me in advance...... sorry bad english br notgood |
11-24-2007, 10:31 | #4 (permalink) | ||
Member: 355635 Status: Offline Thanks Meter: 53 | Quote:
Quote: THX for quick reply ..... i do like both of u said and the phone can be unlock now..... this is the log ==== log opened: [11/24/2007 4:23:55 PM] ==== Application: C:\Program Files\InfinityBox\QModule\QModule.exe Loading data, wait... [Infinity Box] v2.20 S/N: 2143:010C Wait... Current device: Panasonic-X300 Done COM6 selected Device: Panasonic-X300 Checking data, wait... Action: Unlock Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 98007400000012:98E59F00000000 flash: Toshiba 50VSF5782 T 8Mb id: 00005279 Boot Done Set baud... 115200 Set baud Done Check Flash... Check Flash Done Check space... file saved: backup_eeprom_unlock-1_20071124-162619.04E.bin Check space Done Check parameters... Check parameters Done Format file system... area-01... area requested/selected: 02/02 Format file system Done Write... Preparing... area requested/selected: 02/02 Write Done Finished Remove/Install battery now ! Time used: 15 sec well. that's all, thx WBR notgood | ||
02-04-2008, 11:12 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, explain what you have too and what is the problem exactly. Also, please, check this link if you have any kind of connection problems: http:///vbb/showthread.php?t=342807 |
02-08-2008, 09:41 | #7 (permalink) |
Banned Join Date: Apr 2007
Member: 480351 Status: Offline Thanks Meter: 5 | COM4 [VCP0] selected Device: Panasonic-X300 Checking data, wait... Action: Reset Boot... Press and HOLD Power button ! Connecting, wait... error: boot failed: 19 Release Power button ! error: wrong answer, errorcode#37 Boot Fail error: wrong answer[3B] Finished Remove/Install battery now ! Time used: 2 sec |
02-08-2008, 09:48 | #8 (permalink) |
Member: 480351 Status: Offline Thanks Meter: 5 | NOW.... COM4 [VCP0] selected Device: Panasonic-X300 Checking data, wait... Action: Reset Boot... Press and HOLD Power button ! Connecting, wait... error: boot failed: 3B possible error: Power key released too fast, need to keep Power key pressed during boot procedure. Release Power button ! error: wrong answer, errorcode#37 Boot Fail error: wrong answer[3B] Finished Remove/Install battery now ! Time used: 16 sec |
02-08-2008, 14:22 | #9 (permalink) | |
Please, read text marked in red color and follow this advice. | |
02-09-2008, 13:22 | #10 (permalink) |
Member: 480351 Status: Offline Thanks Meter: 5 | COM4 [VCP0] selected Device: Panasonic-X300 Checking data, wait... Action: Reset Boot... Press and HOLD Power button ! Connecting, wait... error: boot failed: 19 Release Power button ! error: wrong answer, errorcode#37 Boot Fail error: wrong answer[B3] Finished Remove/Install battery now ! Time used: 48 sec with : Power key released too fast, need to keep Power key pressed during boot procedure. still error |
02-09-2008, 14:10 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Did you checked FAQ thread ? http:///vbb/showthread.php?t=342807 As I remember it was quite clear explanations regarding X300 connection problems, f.e. how to cut cable connector rubber around metal pin to be sure that cable inserted in phone connector completely. |
please help me to unlock N97 [ANSWERED] | longgiang81 | Genie Universal | 2 | 03-30-2010 09:18 |
problem of pan x300 | MGT SOFTWARE | Infinity-Box | 3 | 12-07-2006 18:25 |
Pan X300 firmware flash need... | guessgaus | Panasonic | 1 | 10-09-2006 03:42 |
help...! Panasonic X300 stays at Panasonic after unlocking with PanaUFO 3.2 | jache_1011 | Panasonic | 13 | 03-06-2006 00:52 |
how can i put pan x300 in test mode? | florinfr80 | Panasonic | 5 | 02-23-2005 12:20 |
