11-28-2011, 14:33 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, PCB looks very similar. Did you tried to read full flash like "X930" model ? "flash read" operation can not damage phone in any case. if you will have a success with flash reading, pls send full flash backup file (or link) to [email protected] |
11-28-2011, 20:45 | #4 (permalink) |
No Life Poster Join Date: Feb 2003 Location: africa Age: 54
Member: 22284 Status: Offline Thanks Meter: 81 | COM5 [VCP0] selected module v4.07 Device: ZTE-X930 Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0053]: 00AD:00A100800015 [HYNIX] H8BCS0PG0MBP chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: X930_V1_Z3_ZA_ZA_B1FF102 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: ZTEMT35_09B_BOOTLOADER_V005_MT6235B_X930_V1_Z3_ZA_ ZA_B1FF102.bin nfi area detection (3 cores) finished: Ok warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: ZTEMT35_09B_PCB01_GPRS_MT6235B_S01.X930_V1_Z3_ZA_Z A_B1FF102.BIN_FLNH8ACS0PG0MBP_56M project-id: X930_V1_Z3_ZA_ZA_B1FF102, 00000000 code offset: 00000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.4.07, database date: 09.11.2011): ZTEMT35_09B_PCB01_GPRS_MT6235B_S01.X930_V1_Z3_ZA_Z A_B1FF102.BIN_FLNH8ACS0PG0MBP_56M This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== area size: 128Mb number of areas/bytes to read: 1:08000000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... file saved: C:\Documents and Settings\Vin\Desktop\ZTE-X930_ZTEMT35_09B_PCB01_GPRS_MT6235B_S01.X930_V1_Z3 _ZA_ZA_B1FF102.BIN_FLNH8ACS0PG0MBP_56M__firmware_2 0111128-214358.B4M.bin Disconnect... done Finished, time used: 49 min 36 sec Remove/Install battery now ! |
06-13-2013, 10:42 | #11 (permalink) | |
Just run software, select your phone model (Vodafone-553) and make operation that you need. If you will have any problems - post here detailed problem description and operation log text so we will be able to check what is wrong. Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update: Infinity-Box - News - 26-05-2013 - Online Service Updated 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell. It's just an example for Alcatel, if you have another model you must select your model ! RJ45 connector pinout: Here is an information how to build your own cable: FAQ: Frequently Asked Questions, cables/pinouts | |
06-13-2013, 16:54 | #12 (permalink) | |
No Life Poster Join Date: Oct 2005
Member: 194907 Status: Offline Thanks Meter: 114 | Quote:
Current dongle firmware version:0118 Reguired dongle firmware version:0120 | |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
