10-20-2007, 12:48 | #1 (permalink) |
No Life Poster Join Date: Mar 2004 Age: 44
Member: 58764 Status: Offline Thanks Meter: 95 | Help Plz D66+ Dead lcd blach not resulta plz help repaire my lcd black thx infinity for replaiAction: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6226, E02 Hardware version: M500Z_05C_HW Software version: E553_K9F8.00.0_26S01 Software date: 2005.04.12 Barcode: MT012345678901234567 imei: 135790246811220 wat is ?????? Finished, time used: 10 sec Power off phone now ! |
10-25-2007, 08:48 | #7 (permalink) | |
Product Supporter Join Date: Sep 2004 Location: *In the right way*
Member: 84268 Status: Offline Sonork: 100.114149 Thanks Meter: 2,569 | Quote:
So, if END-USER (the guy who use/operate the box) have some experience and USE HIS BRAIN, usually all should work well and there will be not any damaged phones. But unfortunately not all end-users got this "requirements" for using infinity box ... | |
10-25-2007, 08:58 | #8 (permalink) |
No Life Poster Join Date: Nov 2005 Location: .:GSM WORLD:.
Member: 203158 Status: Offline Sonork: 100.1592032 Thanks Meter: 358 | yes this is true u r absolutely right Zinoubinail ..... As far as i didnt read the infinty Documentation i wasn`t able to operate the Box easily .. but now if any unique phone came to me like yesterday i did VK200 i straight away go to Documentation part and read out my required material and do my operations easily some time even without chekin the forum .... so all i have to say is infinity Documentation is very good users must read it first and then post problems in forum ... this will be definately helping u ppzz regards Bhattimobilfone |
10-25-2007, 11:39 | #9 (permalink) | |
Member: 58764 Status: Offline Thanks Meter: 95 | Quote:
10-25-2007, 12:13 | #10 (permalink) |
Member: 84268 Status: Offline Sonork: 100.114149 Thanks Meter: 2,569 | no problem dear zakk 1. Learn some english or find a friend to translate for you ... 2. READ and try to UNDERSTAND documentation file !!! 3. Read this forum, there is A LOT of informations and solutions (but for this you should understand english too) If you will do 1-3 you will be able to solve your problems ... |
10-25-2007, 15:48 | #12 (permalink) |
Freak Poster Join Date: Mar 2004 Location: rap3g Age: 44
Member: 59209 Status: Offline Thanks Meter: 19 | plz mr zinoubi don't waste u'r time with unfrutfull threads no need for all these unraisonble factés he have 9 years inthis field he always unlocks the impossible and have problemes with the no probleme i'll try to translate all softwares into arabic luanguage that's will be more easyer for u man :d |
10-25-2007, 16:54 | #14 (permalink) | |
No Life Poster Join Date: Mar 2002 Location: tunis,tunisia Age: 48
Member: 10396 Status: Offline Thanks Meter: 32 | Quote:
10-25-2007, 16:59 | #15 (permalink) |
No Life Poster Join Date: Nov 2005 Location: ABouSHaDy Age: 48
Member: 200717 Status: Offline Sonork: 100.1580056 Thanks Meter: 793 | to zakk_bhim lolololol u phone resolved by tuniserv thx to infinity team or dream ==== log opened: [22/10/2007 19:48:05] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.57 S/N: 2296:010C Wait... Device: Autodetect 6205-6227 NOR Done WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? operation aborted WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? COM2 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: reset Boot... Press and HOLD Power button now ! baud autodetection active error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 141 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... COM2 [VCP0] selected Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6226:8A02]... Connecting, wait... error: can't finalize test moide Operation failed ! Finished, time used: 22 sec Remove/Install battery now ! Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6226, E02 Hardware version: M500Z_05C_HW Software version: E553_K5SMCHARAB.01.1 Software date: 2005.04.12 Barcode: MT012345678901234567 imei: 135790246811220 Finished, time used: 5 sec Power off phone now ! Action: read codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... COM2 [VCP0] selected Phone should be Switched OFF ! Press and HOLD Power button now ! error: can't activate test moide Operation failed ! Finished, time used: 1 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? COM2 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: reset Boot... Press and HOLD Power button now ! baud autodetection active error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 53 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? COM2 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: reset Boot... Press and HOLD Power button now ! baud autodetection active error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 101 sec Remove/Install battery now ! Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 29 sec Power off phone now ! Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 78 sec Power off phone now ! Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6226, E02 Hardware version: M500Z_05C_HW Software version: E553_K5SMCHARAB.01.1 Software date: 2005.04.12 Barcode: MT012345678901234567 imei: 135790246811220 Finished, time used: 7 sec Power off phone now ! Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6226, E02 Hardware version: M500Z_05C_HW Software version: E553_K5SMCHARAB.01.1 Software date: 2005.04.12 Barcode: MT012345678901234567 imei: 135790246811220 Finished, time used: 5 sec Power off phone now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! |
need help plz V980 dead | sheikhje | Smart-Clip | 2 | 12-17-2005 12:11 |
help plz with dead T65 | Bomber | Sony Ericsson | 5 | 02-14-2005 10:44 |
Help Plz With Dead Gd67 | blinet | Panasonic | 2 | 02-28-2004 21:42 |
Help plz, another dead T10s | Kevko | Old Ericsson Phones & Sony Phones | 1 | 10-12-2000 07:39 |
Help plz, another dead T10s | Kevko | Old Ericsson Phones & Sony Phones | 0 | 10-11-2000 22:32 |
