10-22-2017, 15:01 | #1 (permalink) |
No Life Poster Join Date: Apr 2017
Member: 2711286 Status: Offline Thanks Meter: 27 | help to read pattern lock f3 plus 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 652 [MSM8952] ID_BLOCK_S : 81BE5C28 ID_BLOCK_I : 009900E1 ID_BLOCK_L : 4A9F1ED921EDD0013042D96DAFC5E507 ID_BLOCK_L : E9A345E7B8FBCD1654684F1A46E4A747 Use CM2 Internal Loader FH_LOAD_CODE : 14 Error : Loader send failed! Check cable, connection and drivers! Reconnect Power/Cable! |
10-23-2017, 23:38 | #5 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,784 | All I have is Download Agent and Auth files ... If you find scatter file, you can play with phone, via SPFlashTools... b.r. ALex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
