Help to repair imei error corupto ref mt-6223 ==== log: [29/09/2009 08:20:23 p.m.] ==== COM4 [VCP0] selected module v2.91 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write method: mode-3 imei write channel: imei #1 for dual sim/mono CPU new imei: 904545050000000 ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:13F3:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [enhanced] generation startup code area #1 is Ok startup code area #1 backup saved: C:\Archivos de programa\InfinityBox\ChineseMiracle\backup_securit y\id.B8DAE09A.[PROWAVE23C_GEMINI_08A_PCB01_GPRS_MT6223_S00.A319_0 9_Q1A_R1_0_2_2.BIN_BC1CF7DF].rpl ==================== New firmware detected (v.2.91, database date: unknown): PROWAVE23C_GEMINI_08A_PCB01_GPRS_MT6223_S00.A319_0 9_Q1A_R1_0_2_2.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished device-id: B8DAE09A rom info protocol ver: 04 ver. sw 1: PROWAVE23C_GEMINI_08A_PCB01_GPRS_MT6223_S00.A319_0 9_Q1A_R1_0_2_2.BIN ver. sw 2: A319_09_Q1A_R1.0.2.2, 2008E343 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC257E25082501:2BEA0000000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent startup code area #1 check... startup code area #1 fixed detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: PROWAVE23C_GEMINI_08A_PCB01_GPRS_MT6223_S00.A319_0 9_Q1A_R1_0_2_2__ffs... file saved: C:\Archivos de programa\InfinityBox\ChineseMiracle\PROWAVE23C_GEM INI_08A_PCB01_GPRS_MT6223_S00.A319_09_Q1A_R1_0_2_2 __ffs_20090929-202403.B0E.bin flash: EC257E25082501:2BEA0000000000 Backup required data Done Patch required data ... imei is not detected ! What to do: 1. Power-On phone 2. wait 20-30 sec 3. Power-Off by "Power" button, don't remove battery ! 4. Repeat "repair imei" procedure again If imei can't be detected: 1. make "complete" ffs/eeprom format 2. Power-On phone 3. wait 20-30 sec 4. Power-Off by "Power" button, don't remove battery ! 5. Repeat "repair imei" procedure again If imei can't be detected: read flash and send to support: [email protected] Patch required data Fail file saved: C:\Archivos de programa\InfinityBox\ChineseMiracle\backup_securit y\PROWAVE23C_GEMINI_08A_PCB01_GPRS_MT6223_S00.A319 _09_Q1A_R1_0_2_2__system_log_B8DAE09A_BC1CF7DF_200 90929-202411.B0X.bin Finished, time used: 225 sec Remove/Install battery now ! |
hello! please send this full flash to [email protected] have you tried to change IMEI on powered On phone with changing method-1? also try via test mode with method-2 |
