Old 09-30-2009, 03:36   #1 (permalink)
Crazy Poster
Member: 395785
Thanks Meter: 20
Unhappy Help to repair imei error corupto ref mt-6223
==== log: [29/09/2009 08:20:23 p.m.] ====
COM4 [VCP0] selected
module v2.91
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: "repair imei"
imei write method: mode-3
imei write channel: imei #1 for dual sim/mono CPU
new imei: 904545050000000
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
high speed boot On
chip: 0011:13F3:000C
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: EC257E25082501:2BEA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
921600
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device rom info...
detection phase #1...
detect device rom info finished
rom info structure: 2nd [enhanced] generation
startup code area #1 is Ok
startup code area #1 backup saved: C:\Archivos de programa\InfinityBox\ChineseMiracle\backup_securit y\id.B8DAE09A.[PROWAVE23C_GEMINI_08A_PCB01_GPRS_MT6223_S00.A319_0 9_Q1A_R1_0_2_2.BIN_BC1CF7DF].rpl
New firmware detected (v.2.91, database date: unknown):
This firmware is missing in support area. If this phone is good and working:
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
device-id: B8DAE09A
rom info protocol ver: 04
ver. sw 1: PROWAVE23C_GEMINI_08A_PCB01_GPRS_MT6223_S00.A319_0 9_Q1A_R1_0_2_2.BIN
ver. sw 2: A319_09_Q1A_R1.0.2.2, 2008E343
ffs offset/size: 00E00000/00200000
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
detecting startup code area #2...
startup code area #2 is absent
startup code area #1 check...
startup code area #1 fixed
detect device sec info...
detect device sec info finished
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: PROWAVE23C_GEMINI_08A_PCB01_GPRS_MT6223_S00.A319_0 9_Q1A_R1_0_2_2__ffs...
file saved: C:\Archivos de programa\InfinityBox\ChineseMiracle\PROWAVE23C_GEM INI_08A_PCB01_GPRS_MT6223_S00.A319_09_Q1A_R1_0_2_2 __ffs_20090929-202403.B0E.bin
Backup required data Done
Patch required data ...
imei is not detected !
What to do:
1. Power-On phone
2. wait 20-30 sec
3. Power-Off by "Power" button, don't remove battery !
4. Repeat "repair imei" procedure again
If imei can't be detected:
1. make "complete" ffs/eeprom format
2. Power-On phone
3. wait 20-30 sec
4. Power-Off by "Power" button, don't remove battery !
5. Repeat "repair imei" procedure again
If imei can't be detected: read flash and send to support: [email protected]
Patch required data Fail
file saved: C:\Archivos de programa\InfinityBox\ChineseMiracle\backup_securit y\PROWAVE23C_GEMINI_08A_PCB01_GPRS_MT6223_S00.A319 _09_Q1A_R1_0_2_2__system_log_B8DAE09A_BC1CF7DF_200 90929-202411.B0X.bin
Finished, time used: 225 sec
Remove/Install battery now !
Old 09-30-2009, 23:24   #2 (permalink)
Member: 148515
Thanks Meter: 14,898
hello!
please send this full flash to [email protected]
have you tried to change IMEI on powered On phone with changing method-1?
also try via test mode with method-2
help to repair imei in top1 rehmani Infinity-Box 7 05-13-2010 22:00
help to repair imei in top1 rehmani Infinity-Box 7 03-03-2010 22:47
1200 ???????? imei convert to 1208 try to repair imei by mx-key but some error appear mine4ever Nokia Digital Core Technology 4 ( DCT-4 ) 1 01-16-2010 13:36
need help to repair imei kg110 ameho0102 Infinity-Box 5 11-03-2009 10:12
How to repair imei error in panasonic x300 SUUNNYY PolarBox 3 0 11-11-2008 13:58
Page generated in 0.24725 seconds with 8 queries
