Old 08-06-2008, 18:00   #1 (permalink)
Member: 136838
help superfone sf-9080 pinout
Old 08-07-2008, 15:39   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
What is phone bottom connector type ?
Old 09-17-2008, 18:40   #3 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,593
1x20 sir..
and pin finder didnt find it.. and there are some points on the board that not called rx or tx or gnd.. but i forund power on\off
pls check the points..
MCU
o (gnd) o o o
o
o
o
o
o (power on\off)
Old 09-17-2008, 18:48   #4 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,593
Originally Posted by LoveLess View Post
1x20 sir..
MCU
o (gnd) o o o
o
o
o
o
o (power on\off)
pin finder error...
software version: 1.14
cable type: 1x20 (L20A)
platform: MT: MT62xx (autodetect)
searching adapter at COM2...
adapter found, version: 2000
pins: 20, plain
power cycles: 1
activation cycles: 7
power-off delay: 20
start Rx/Tx: 1/1
Loading configuration...
Initializing...
Press and HOLD phone Power button now !
detecting pins...
19200 fixed
19200 fixed
19200 fixed
19200 fixed
19200 fixed
19200 fixed
19200 fixed
19200 fixed
19200 fixed
error: boot initialization step-2 failed: B0
19200 fixed
19200 fixed
19200 fixed
19200 fixed
19200 fixed
failed to detect pins
time required: 168 sec
Power Off !
Old 09-17-2008, 18:49   #5 (permalink)
Member: 130995
Hello,
What is phone CPU chip name ?
Can you attach PCB photo ?
Old 09-17-2008, 18:53   #6 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,593
1x20 sir..
MCU
o (gnd) o o o
o
o
o
o
o (power on\off)
and when i boot it with point on the boards gives this error tooo..
pins: 20, plain
power cycles: 1
power-off delay: 20
start Rx/Tx: 1/1
Initializing...
detecting pins...
error: boot initialization step-2 failed: A0
error: boot initialization step-3 failed: A0
19200 fixed
error: boot initialization step-2 failed: F8
error: boot initialization step-2 failed: 00
19200 fixed
error: boot initialization step-2 failed: FC
time required: 160 sec
Power Off !
Old 09-17-2008, 19:06   #7 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,593
Hello,
hi sir..
it has mt6226ba cpu..and i will add pcb phote a few min. later..
thanx alot..
Old 09-17-2008, 19:22   #8 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,593
Hello,
pics r not clearly.. i marked the pins.. pls check it sir..
Old 09-18-2008, 00:27   #9 (permalink)
Member: 130995
Hello,
Old 09-18-2008, 14:04   #10 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,593
Originally Posted by infinitysupport View Post
hello,
what is phone cpu chip name ?
arm
mt6226ba
0740-boal
dp4591
Old 09-18-2008, 17:23   #11 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,593
nobody has any idea..? or pinout..? it is a bit urgent..
Old 09-19-2008, 21:54   #12 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,593
Hello,
sir..
is there any news about this phone..?
b.r..
Old 09-19-2008, 22:37   #13 (permalink)
Member: 148515
Thanks Meter: 14,898
hello!
you must examinate this test points with multimeter with attached battery
when you see voltages 2,7-2,9 volts- those will be tx/rx
Old 09-19-2008, 23:16   #14 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,593
hello!
oki sir.. i will check the points...
thanx alot..
Old 03-24-2009, 11:41   #15 (permalink)
Crazy Poster
Member: 56692
Thanks Meter: 2
unfortunately i don`t have another pcb photo.
you can remove the esd filter ic;
another way is to remove the resistors;
if don`t work,try to invert rx / tx ,cos` i`m not sure about that
this is pinout for CPU-A (MT6226BA)
CPU-B is another manufacturer ( SKYWORKS , i think)
so you can`t yet communicate with CPU-B
The Following User Says Thank You to arness For This Useful Post:
superfone sf 9080 pınout muratcan Infinity-Box 3 11-26-2008 18:56
SuperFone SF-9028 Pinout.. LoveLess Infinity-Box 0 08-25-2008 16:09
can sum1 please help me with m35 pinouts Zianna x1x to x45/x50 1 04-10-2001 10:45
HELP - I need GD92 pinout ! Liquid Panasonic 1 10-23-2000 04:46
Help with Aeg telit pinouts MisterMister Various 0 11-11-1999 01:27
Page generated in 0.44857 seconds with 9 queries
