05-07-2007, 18:14 | #1 (permalink) |
Freak Poster Join Date: Oct 2006 Location: midnapur west
Member: 378776 Status: Offline Thanks Meter: 20 | help to unlock BenQ-Siemens A38(airsel) > COM19 selected > Device: BenQ A38 > Checking data, wait... > Action: Unlock > Boot... > Phone should be Switched OFF ! > Press Power button now ! > Connecting... > Boot Done > Check Connection... > Check Connection Done > Set Baud... > Set Baud Done > Check Flash... > Check Flash Done > Check Parameters... > Flash: 0001:227E221D2200 > Err: not locked or unknown eeprom > Check Parameters Fail > Finished, time used: 39 sec > Remove/Install battery now ! |
The Following User Says Thank You to rajivmobil For This Useful Post: |
05-09-2007, 12:13 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | 1. read flash from phone 2. send flash backup with detailed description of problem to [email protected] 3. flash phone with flash files from support area |
05-09-2007, 12:18 | #5 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: jharkhand jamshedpur INDIA Age: 38
Member: 226587 Status: Offline Sonork: 100.1603781 Thanks Meter: 352 | Quote:
b,r yuvi, | |
The Following User Says Thank You to Yuvi For This Useful Post: |
05-10-2007, 04:53 | #6 (permalink) |
Member: 378776 Status: Offline Thanks Meter: 20 | flash backup with detailed description of benq semens COM19 > selected > Device: BenQ A38 > Checking data, wait... > Action: Read flash > Boot... > Phone should be Switched OFF ! > Press Power button now ! > Connecting... > Boot Done > Check Connection... > Check Connection Done > Set Baud... > Set Baud Done > Check Flash... > Check Flash Done > Check Parameters... > part 1 of 1... > Reading... > file saved: > Backup_full_part_1_of_1_2007-5-5_18-5-47.6BX.bin > Flash: 0001:227E221D2200 > Finished, time used: 429 sec > Remove/Install battery now ! |
07-07-2008, 10:59 | #9 (permalink) |
Registered User Join Date: Feb 2004 Location: Bangladesh Age: 50
Member: 52964 Status: Offline Thanks Meter: 5 | a38 dead, write eeprom but phone not power on Boot Done Check Connection... Check Connection Done Set Baud... 812500 Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0001:227E221D2200 flash: Amd S29GL032A-U r1,r2,r8,r9 U 4Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Eeprom Flash: 0001:227E221D2200 flash: Amd S29GL032A-U r1,r2,r8,r9 U 4Mb Writing Done Finished, time used: 30 sec Remove/Install battery now ! |
pls mastercode to unlock benq-siemens EF81 | mangaietorul | Phone Unlocking Codes & Maps | 0 | 08-25-2008 09:44 |
how to unlock benq siemens EL71 | mohamedrimas | DreamBox | 2 | 05-16-2008 14:37 |
how to unlock Benq siemens AP75 | dompezvicky | Infinity-Box | 1 | 03-23-2007 09:25 |
Help me to unlock Benq- Siemens SFG75 | bogdancirlogea | Infinity-Box | 1 | 12-13-2006 14:18 |
