Unlock Server
Old 01-11-2011, 21:37   #1 (permalink)
Rey_negro's Avatar
Member: 417512
HELP to unlock coral 280
I want to know if you can help to unlock this model.
Read backup with model: bleu 255, I try to flash the phone with firmware of coral 255 and 550 and phone become dead, then flash the backup and live again.
Phone Details:
Marca: Coral
Model: 280
Text from back label:
Model: c280/9
FCC ID: T38PCD1032
Band: 900/1800
Pinout: (same as coral 620, 640, 655, utstarcom 1238, 1328, etc)
Cable name: SFR-341
connector 2x5 (L10C)
/1 2 3 4 5\
|6 7 8 9 10|
4: box Rx/phone Tx/PinFinder Rx (RJ45 pin-3)
5: box Tx/phone Rx/PinFinder Tx (RJ45 pin-2)
6: Gnd (RJ45 pin-8)
Here is the backup:
(full flash, firmware and Eeprom)
http://rapidshare.com/files/442051694/280.rar
Here is log:
==== [11/01/2011 02:20:20 p.m.] ====
COM3 [VCP0] selected
module  v3.72
Device: Bleu-255x
Checking data, wait...
Action: read ffs/eeprom
ffs/eeprom backup enabled, it may takes several minutes !
====>  Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:4C0C:000C
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====>  Initialize ...
flash: EC257E25062501:2CEA0000000000
flash: Micron/Silicon7 AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb
otp offset: 00000000
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
====>  Set baud ...
921600
Set baud Done
====>  Initialize bootcode ...
Initialize bootcode Done
====>  Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [protected] type (07), 1 record(s)
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: D:\Archivos de programa\InfinityBox\MModule\backup_security\id.47201FCF.[CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223_S00.C1032_2_2_0X11106_EU_DIGICEL_SAMSUNG_P1.BIN_8D6F0469].rpl
New firmware found (v.3.72, database date: 23.12.2010):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: support@infinity-box.biz or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
device-id: 47201FCF
rom info ver: 07
sw version: CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223_S00.C1032_2_2_0X11106_EU_DIGICEL_SAMSUNG_P1.BIN
project-id: C1032_2.2_0x11106_EU_DIGICEL_SAMSUNG_P1, 69046F8D
code offset: 00000000
ffs offset/size [02]: 00700000/00100000
TCL-ID is absent
ffs/eeprom address assigned: 00700000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====>  Check firmware content ...
Check firmware content Done
====>  Backup required data ...
reading: Bleu-255x_CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223_S00.C1032_2_2_0X11106_EU_DIGICEL_SAMSUNG_P1__ffs...
file saved: C:\Celulares\Infinity BOX\Firmware\Coral\280\Bleu-255x_CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223_S00.C1032_2_2_0X11106_EU_DIGICEL_SAMSUNG_P1__ffs_20110111-142436.B0E.bin
file saved: D:\Archivos de programa\InfinityBox\MModule\backup_security\Bleu-255x_CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223_S00.C1032_2_2_0X11106_EU_DIGICEL_SAMSUNG_P1__system_log_47201FCF_8D6F0469_20110111-142546.B0X.bin
Finished, time used: 5 min 5 sec
Remove/Install battery now !
==== [11/01/2011 02:25:48 p.m.] ====
module  v3.72
Device: Bleu-255x
Action: read flash
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
status: FF
Boot Done
Initialize Done
====>  Set baud ...
921600
Set baud Done
TCL-ID is absent
device-id: 47201FCF
rom info ver: 07
TCL-ID is absent
reading: Bleu-255x_CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223_S00.C1032_2_2_0X11106_EU_DIGICEL_SAMSUNG_P1__fullflash_part_1_of_1...
file saved: C:\Celulares\Infinity BOX\Firmware\Coral\280\Bleu-255x_CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223_S00.C1032_2_2_0X11106_EU_DIGICEL_SAMSUNG_P1__fullflash_part_1_of_1_20110111-143412.B0M.bin
file saved: D:\Archivos de programa\InfinityBox\MModule\backup_security\Bleu-255x_CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223_S00.C1032_2_2_0X11106_EU_DIGICEL_SAMSUNG_P1__system_log_47201FCF_8D6F0469_20110111-143442.B0X.bin
Finished, time used: 8 min 49 sec
==== [11/01/2011 02:34:45 p.m.] ====
module  v3.72
Device: Bleu-255x
Action: read firmware
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
status: FF
Boot Done
Initialize Done
====>  Set baud ...
921600
Set baud Done
TCL-ID is absent
device-id: 47201FCF
rom info ver: 07
TCL-ID is absent
reading: Bleu-255x_CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223_S00.C1032_2_2_0X11106_EU_DIGICEL_SAMSUNG_P1__firmware_part_1_of_1...
file saved: C:\Celulares\Infinity BOX\Firmware\Coral\280\Bleu-255x_CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223_S00.C1032_2_2_0X11106_EU_DIGICEL_SAMSUNG_P1__firmware_part_1_of_1_20110111-144046.B0M.bin
error: can not make firmware backup
file saved: D:\Archivos de programa\InfinityBox\MModule\backup_security\Bleu-255x_CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223_S00.C1032_2_2_0X11106_EU_DIGICEL_SAMSUNG_P1__system_log_47201FCF_8D6F0469_20110111-144118.B0X.bin
Finished, time used: 6 min 28 sec
Loading file v.02...
coral255-255x_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.SFE-DIG9-P109A14V1_0_0B04__ffs_20100807-001127.B0E.bin loaded
If you need something else let me know
Thanks
Old 01-12-2011, 13:35   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Hello,
We will check backup file fast.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 01-12-2011, 20:07   #3 (permalink)
Rey_negro's Avatar
Member: 417512
Can you tell what file from support can use to flash this phone and work with frecuency 850/1900?
Thanks
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 28 08-30-2012 03:40
HELP!!! BACKGROUND SCREEN LOGO Michael Go Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-25-2011 23:56
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-18-2011 11:00
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
Page generated in 0.40242 seconds with 11 queries
