02-18-2010, 16:07 | #3 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | GB102 exist in software list, it's no need to select any other model. How to write flash (upgrade/downgrade firmware, change language): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to read flash: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Read flash" (or "Read full flash") button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not works try to make "complete" format (if this option exist) 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software |
Have any way to unlock LG GB102??? | svchost | Z3X-Team Products | 4 | 06-20-2009 09:46 |
need help to unlock lg phones with red box | gdgsm | Redbox | 1 | 02-25-2005 11:22 |
Need help to unlock LG C1200 with BLAZER | dominik | LG | 1 | 06-21-2004 17:52 |
Help to unlock LG 5300 | gabrielgsm | LG | 0 | 07-20-2003 17:18 |
Need help to unlock LG W3000 and W7000 via IMEI | sp-lox | LG | 0 | 07-14-2003 15:11 |
