12-11-2008, 12:42 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Tunisia
Member: 261437 Status: Offline Sonork: no Thanks Meter: 922 | help to unlock SE j132 with InfinityBo+Pinfinder COM7 [VCP0] selected module v1.30 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: FDBC Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 48 sec Remove/Install battery now ! thanks |
12-11-2008, 12:45 | #2 (permalink) |
Member: 261437 Status: Offline Sonork: no Thanks Meter: 922 | Same phone but different rom version COM7 [VCP0] selected module v1.30 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 693C Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 48 sec Remove/Install battery now ! |
12-11-2008, 17:07 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @noure30 I think it's cable/pinout communication problem die to software can not connect to phone well and can not read ROM version. Try to use ordinary LG-C2500 cable. |
12-12-2008, 00:10 | #6 (permalink) | |
Freak Poster Join Date: Dec 2006 Location: ib da da dan
Member: 405806 Status: Offline Thanks Meter: 17 | Quote:
do not remove ur hand from the power on button till the process is completed ,have a nice unlocking. i unlock 4pcs instantly.. | |
12-12-2008, 23:42 | #8 (permalink) | |
Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 | |
12-13-2008, 04:44 | #9 (permalink) | |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | Quote:
do what idrisbigdaddy said ... and make sure that your cable and power cable is connected 100 % and Press power button until software not say to release it . test and post results Br Faisal_Computer | |
The Following User Says Thank You to Faisal_Computer For This Useful Post: |
12-13-2008, 11:26 | #11 (permalink) |
Member: 261437 Status: Offline Sonork: no Thanks Meter: 922 | Thanks for all problem solved and se j132 unlocked successfully , her's alog :COM7 [VCP0] selected module v1.30 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 2088C0FFFFFFFF:2088C000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb Check hardware done Read data ... reading Sony-Ericsson-J132_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-J132_eeprom_calibration-1_20081213-111418.80E.bin Read data done Check data ... Check data done Write ... ..... flash: 2088C0FFFFFFFF:2088C000000000 Write: simlock Write done Finished, time used: 78 sec Remove/Install battery now ! |
The Following User Says Thank You to noure30 For This Useful Post: |
01-21-2009, 01:47 | #12 (permalink) |
Freak Poster Join Date: Dec 2002 Location: Zooropa Age: 42
Member: 18832 Status: Offline Thanks Meter: 18 | I used same setting, infinity directly to pc, but i can never get my phone to connect. I used pinfinder with same presets! Phone turns on and nothing happens soft never sees phone. Any idea where it might go wrong? WBR e-studio.hu |
01-21-2009, 15:26 | #13 (permalink) |
Freak Poster Join Date: Apr 2007 Location: morocco
Member: 480799 Status: Offline Thanks Meter: 21 | hi i tray to unlock sej132 , i have this error : COM4 [VCP0] selected module v1.30 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 21 sec Remove/Install battery now tnx |
01-21-2009, 17:53 | #14 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @lc5829 Did you tried to use PinFinder with other phones ? @BIJOU8420 It may be phone with new hardware that is not supported yet. |
01-21-2009, 18:58 | #15 (permalink) |
No Life Poster Join Date: Mar 2004 Location: MX-KEY is the BEST NOKIA TOOL Age: 55
Member: 60178 Status: Offline Thanks Meter: 30 | also me i cant unlock here is log COM4 [VCP1] selected module v1.30 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 47 sec Remove/Install battery now ! and the same version |
Help to unlock se j132 | Tahir Riaz | Infinity-Box | 7 | 01-11-2011 08:37 |
how to unlock se j132 and what cable need to unlock | masslarry | Sony Ericsson | 7 | 09-05-2009 10:10 |
Can i unlock se j132 with UB??? | svchost | Universalbox | 5 | 06-04-2009 20:36 |
pls help to unlocked new j132 with setool | godwin | Sony Ericsson | 2 | 04-20-2009 13:22 |
