07-27-2010, 00:14 | #1 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Central America
Member: 628110 Status: Offline Thanks Meter: 87 | [HELP] Unlocking Bird s230a Movistar GT and try unlock without luck... smart fast Code: COM9 [VCP0] selected module v3.52 Action: "sp-unlock" unlock method: smart fast Model: Bird-S230 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:3C2C:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: V1.091110_S230TEM_GT_V4 Version: BIRD23P_GPRS07A_HW 44 byte(s) read imei: 01190800021203 connection Ok 157 byte(s) read reading data... reading data #2... building new data... writing data... 145 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 51 sec Remove/Install battery now ! Code: COM9 [VCP0] selected module v3.52 Device: Bird-S230 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:3C2C:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] type TCL-ID is absent rom info detection finished rom info ver: 04 sw version: S230_TEM_GT_PCB01_GPRS_MT6223P_S00.V1_091110_S230TEM_GT_V4.BIN project-id: V1.091110_S230TEM_GT_V4, 00000000 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 rom info structure: 2nd [standard] type TCL-ID is absent ffs/eeprom address assigned: 00C00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 98000300000001:2AEA0000000000 Backup required data Done ====> Patch required data ... ............................... lock area found ............................... lock area found Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 98000300000001:2AEA0000000000 flash: 98000300000001:2AEA0000000000 Write: lock-area-1 flash: 98000300000001:2AEA0000000000 flash: 98000300000001:2AEA0000000000 Write: lock-area-4 Write Done ====> Finalization ... Finalization Done Finished, time used: 1 min 2 sec Remove/Install battery now ! FULL FLASH Bird-S230_S230_TEM_GT_PCB01_GPRS_MT6223P_S00.V1_091110_ S230TEM_GT_V4__fullflash_part_1_of_1_20100725-050426.B0M.bin |
07-28-2010, 18:38 | #6 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Central America
Member: 746276 Status: Offline Sonork: 100.1609752 Thanks Meter: 675 | You're wrong, the correct MCC/MNC is 70403 (Movistar Guatemala) because the one you provided belongs to Claro Guatemala. You can check it out here: http://es.wikipedia.org/wiki/MCC/MNC |
09-23-2010, 20:32 | #9 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | 1. make full flash backup 2. try to flash phone with this firmware: Bird-S230a_S230_DOMINICAN_PCB01_GPRS_MT6223P_S00.V1_00_ 01_M090717DOM850-V38_En_Fr_Es_Pt.B0M.bin 3. make "sp-unlock" What is the results ? |
