05-18-2006, 21:57 | #1 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Sao Paulo - BRAZIL Age: 49
Member: 26751 Status: Offline Thanks Meter: 2 | Lobster problem Device: Lobster 485 Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... FLASH: 0001:227E22212200 Check Space Done Check Data... Err: not locked or unknown eeprom Check Data Fail Finished Remove/Install battery now ! Time used: 68 sec Tried several times. Now I am uploading backup to rapidshare... BR, UnlockBR |
05-20-2006, 11:30 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, What is with phone now ? What you see on LCD when you insert SIM card ? Send me full log to mail (part of log that you posted here is a log after several unlock tries, there is no info about first unlock try). |
05-20-2006, 12:56 | #5 (permalink) |
Member: 26751 Status: Offline Thanks Meter: 2 | Phone is working okay. Here it goes: ---------------- Log opened: [18/5/2006] [16:14:26] App: C:\Program Files\InfinityBox\Lobster\Lobster.exe [Infinity Box] v.1.00A Loading, wait... S/N: 05BA:0108 Wait... Current device: Lobster 485 Done COM1 selected Device: Lobster 485 Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... FLASH: 0001:227E22212200 Check Space Done Check Data... Check Data Done Erasing... Erasing Done Writing... Err: no any answer Writing Fail Finished Remove/Install battery now ! Time used: 97 sec COM1 selected Device: Lobster 485 Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Part 1 of 3... In progress... Part 2 of 3... In progress... Part 3 of 3... In progress... FLASH: 0001:227E22212200 FLASH: 0001:227E22022201 FLASH: 0001:227E22022201 Finished Remove/Install battery now ! Time used: 2247 sec COM1 selected Device: Lobster 485 Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! Err: boot error[02] Boot Fail Finished Remove/Install battery now ! Time used: 22 sec COM1 selected Device: Lobster 485 Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... FLASH: 0001:227E22212200 Check Space Done Check Data... Check Data Done Erasing... Erasing Done Writing... Writing Done Finished Remove/Install battery now ! Time used: 24 sec COM1 selected Device: Lobster 485 Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... FLASH: 0001:227E22212200 Check Space Done Check Data... Err: not locked or unknown eeprom Check Data Fail Finished Remove/Install battery now ! Time used: 20 sec COM1 selected Device: Lobster 485 Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! Err: boot error[03] Boot Fail Finished Remove/Install battery now ! Time used: 10 sec COM1 selected Device: Lobster 485 Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! Err: boot error[02] Boot Fail Finished Remove/Install battery now ! Time used: 76 sec COM1 selected Device: Lobster 485 Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! Err: boot error[04] Boot Fail Finished Remove/Install battery now ! Time used: 16 sec COM1 selected Device: Lobster 485 Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... FLASH: 0001:227E22212200 Check Space Done Check Data... Err: not locked or unknown eeprom Check Data Fail Finished Remove/Install battery now ! Time used: 21 sec ---------------- Log opened: [18/5/2006] [17:41:36] App: C:\Program Files\InfinityBox\Lobster\Lobster.exe [Infinity Box] v.1.00A Loading, wait... S/N: 05BA:0108 Wait... ---------------- Log opened: [18/5/2006] [17:42:07] App: C:\Program Files\InfinityBox\Lobster\Lobster.exe [Infinity Box] v.1.00A Loading, wait... S/N: 05BA:0108 Wait... Current device: Lobster 485 Done COM1 selected Device: Lobster 485 Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... FLASH: 0001:227E22212200 Check Space Done Check Data... Err: not locked or unknown eeprom Check Data Fail Finished Remove/Install battery now ! Time used: 68 sec |
05-22-2006, 13:03 | #11 (permalink) | |
Member: 26751 Status: Offline Thanks Meter: 2 | Quote:
Phone is okay.... but not unlocked :S | |
acount id problem.help uregent plz [SOLVED] | dani2080 | PolarBox 3 | 2 | 03-29-2010 12:46 |
25/07/08 Lobster 485 And Lobster 575 Full Support Added ! | DARIFBS | FuriousGold | 1 | 07-25-2008 16:36 |
Lobster problem | FU_Too | VygisToolbox | 2 | 12-08-2005 09:28 |
Lobster Problems | Robo1985 | Various | 0 | 12-07-2005 14:35 |
