10-04-2009, 09:18 | #1 (permalink) |
Junior Member Join Date: Oct 2009
Member: 1132848 Status: Offline Thanks Meter: 0 | Help|what am i doing Worng? Now whan i connect the cable To The USBPORT (on The BOX) and to the Phone Im Runing the Program "ChineseMiracle" Because i Dont Have (didnt Found it Yet) Flash File that Support my Phone... i have N.c.k.l.a N97c whan i Make "Read Full Flash" Im Getting This MSG\Error: COM24 [VCP0] selected module v2.92 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read NOR flash enhanced security fix enabled Boot ... Press and HOLD Power button now ! The Green TX Light on The Infinity Box Is Flashing But Nothing Is Moving!! I Can Wait For Hours And Hours And Still On The Same Phase! I Even Tryed Phone-OFF \Phone - ON I "played" With The M-BUS -F-BUS Button On The IN-Box But Still no Luck Please If Any One Can Help... Please Help Me With this. if this Is Not The Place For this MSG Please Let Me Know Before Locking It Or Move It Where It Should Be.... Thanks. |
10-04-2009, 09:41 | #2 (permalink) | |
Member: 1132848 Status: Offline Thanks Meter: 0 | Cant Edit Sorry For Duble Post: Here Is Anther Error that i Have Just Now: Quote:
10-04-2009, 10:31 | #4 (permalink) | |
Member: 1132848 Status: Offline Thanks Meter: 0 | Quote:
thank you....i Did LOW baud in the Com Port In The Infinity Software... i DID Slowest.... but Still the Same (or From Anther place?) Should The button M-BUS \ F- BUS Should Be IN or OUT (i Have Push Button.... Not Up And Down Button) | |
10-04-2009, 11:27 | #5 (permalink) | |
Please, check this thread first: http://forum.gsmhosting.com/vbb/showthread.php?t=342807 You will get an information how to connect box to PC, how to connect cables to box, how to set box switches correctly. Please, post here information about your results after you will read that thread. Also, what cable you have used for your phone ? What method you have used to find correct pinout ? | |
10-04-2009, 11:41 | #6 (permalink) | |
Ok i will Check It.... Also, what cable you have used for your phone ? For You Qustion...Im Using GF-AT106 \ 343!(2) Cable For my SonyEricsson G715...The Connction Is Fiting Very Good But Cant get the Software To Read \ Flash it i Cant Find Any Where For Flash Files That Support This Type Of Phone What method you have used to find correct pinout ? i Tried using the GND.Rx-Tx Cable. but I cant Find the Correct Rx-Tx......On The Phone.. | |
10-04-2009, 11:49 | #7 (permalink) | |
1. what is your phone CPU chip name 2. where is Rx/Tx/Gnd at your phone bottom connector Post here an answers for both questions. | |
10-04-2009, 14:30 | #9 (permalink) | |
Did you tried to find pinout at phone bottom connector ? C:\Program Files\InfinityBox\pinout\ChineseMiracle\_How_to_fi nd_pinout.jpg | |
04-16-2010, 17:26 | #12 (permalink) |
Freak Poster Join Date: Apr 2005
Member: 141927 Status: Offline Thanks Meter: 27 | CHINNA NOKIA N97C (VODAFONE 225 PIN) software version: 1.19 cable type: 1x8 (L8A) platform: MT: MT62xx (autodetect) searching adapter at COM5... adapter found, version: 2000 pins: 8, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT6225 result: Rx:1 Tx:4 time required: 1 sec Trying to Power-On... Power On ! |
The Following User Says Thank You to pugazhendhi For This Useful Post: |
Please help... what am i doing wrong?? [SOLVED] | bbmad | Cyclonebox | 5 | 12-06-2009 11:36 |
J.a.f can't read info NEED HELP What am i doing wrong? | sonnydelight | J.A.F. By Jafsupport.com | 5 | 09-07-2008 07:40 |
Help, what am I doing wrong? | Caledonian | Ultima Box Light | 2 | 02-04-2007 17:32 |
What am i doing wrong ? help needed | matyjasz | Smart-Clip | 2 | 04-11-2005 16:14 |
What Am I Doing Wrong? ....help Needed... | the gaffer | Panasonic | 0 | 11-24-2004 00:01 |
