03-10-2016, 13:04 | #1 (permalink) |
Freak Poster Join Date: May 2006 Location: Nigeria,Lagos
Member: 275290 Status: Offline Thanks Meter: 50 | Help write error i Read Firmware from this phone successfully MT6575__H02A__H02A__m0__4.2.2__ALPS.ICS2.MP.V1.30 i used Smart AV to scan it, then cant boot i try to flash with the backup but see error please help me the phone Thanks in anticipation |
03-12-2016, 15:30 | #14 (permalink) |
Member: 275290 Status: Offline Thanks Meter: 50 | see Card found : S/N : CFFA7E57 , v0130 Chinese Miracle II [MTK module] v 1.43 Operation : Check / Read Info [ v1.43 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 110100303034473930101D9F54976027 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 4C5C67BB3EB4154D4E3C4D3D749D221B INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : H02A ProdName : m0xx ProdModel : H02A Device : m0 AndroidVer: 4.2.2 MTKxCPU : MT6575 MTKxPRJ : ALPS.ICS2.MP.V1.30 MODEM : BaseBand : MT6575_S01_MAUI_11AMD_W12_22_SP_V24_P1 Done! Elapsed: 00:00:09 Reconnect Power/Cable! |
