helppppppp me phone daed after format ???!!! phone is restart with sim format phone ------------------------------- COM6 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:77A0:25F6 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.9AE9A5DC.[E553_X8PAARTFBT_E553_GPRS_MT6226_S01.01_1.BIN_66C1 185E].rpl identification#1 detection finished device-id: 9AE9A5DC identification#1 protocol ver: 04 ver. sw1: E553_X8PAARTFBT_E553_GPRS_MT6226_S01.01_1.BIN ver. sw2: E553_X8PAARTFBT.01.1, A1E73E99 ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00800000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00620000 Detected eeprom/ffs address is non-standard: 00620000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00620000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 009E0000 ffs chip: 00 eeprom/ffs area: 00000000:00620000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: EC257E25082501:29EA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: EC257E25082501:29EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_9AE9A5 DC_E553_X8PAARTFBT_E553_GPRS_MT6226_S01.01_1.BIN_6 6C1185E_20080815-205535.B0X.bin Finished, time used: 194 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! ------------------------------------------------------- phone not power and i am hold phone power 1 min but not power help me plz plz :confused::confused::confused: |
hello! what phone model is this? |
phone model : ztc zt6688 CPU: MT6226 |
then check |
flash phone with ZTC-ZT6688_E553_Z12VIRUARTH_E553_GPRS_MT6226_S01[1].01_1_16m_En_Ru_Th_Vn_Ar.B0M.bin phone now working 100% thank you infinity team |
