Old 09-02-2009, 07:17   #1 (permalink)
DYNET's Avatar
Member: 320363
Sonork: 100.1578853
Thanks Meter: 3,938
Here important q:?
I HAVE 2 PHONE
MODEL : CHINES SIGMATEL H1
CPU : 6225
FLASH ST: M30L0R7000T0, M36L0R7040T0 T 16Mb
both set exact same
1 ST PHONE WORKING FINE NOT ANY PROBLEM JUST FOR TESTING
2 nd PHONE DEAD COZ ERASED WHOLE FLASH CHIP
NOW Q IS :
WHEN I TRYING TO READ FULL FLASH FROM WORKING PHONE CHINES-MIRACLE 2.91 READING FILE OK BUT FILE SIZE IS 8.00 MB
BUT EXACT PHONE FLASH SIZE IS 16 MB
I HAVE FLASHED PHONE WITH READE 8MB FILE BUT NO LUCK STILL DEAD
WHAT ANY SETTING IN SOFTWARE OR ANY OTHER METHOD FOR READING THANK YOU
BR.DYNET
The Following User Says Thank You to DYNET For This Useful Post:
Old 09-02-2009, 07:39   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Originally Posted by DYNET View Post
I HAVE 2 PHONE
CPU : 6225
both set exact same
NOW Q IS :
BR.DYNET
Hello,
When Infinity-Box software read full flash from phone and save file to disk this file is internally packed (similar to ZIP or RAR), so if you read 16Mb flash from phone you will get file with less size than 16Mb.
Do you see any messages about "new firmware version" during flash read process ?
Are you sure that 2nd phone has no hardware damage ?
Post here flash read log.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 09-02-2009, 08:29   #3 (permalink)
DYNET's Avatar
Member: 320363
Sonork: 100.1578853
Thanks Meter: 3,938
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:9B03:0008
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 2088C4FFFEFFFE:2088C400000000
flash: ST M30L0R7000T0, M36L0R7040T0 T 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device rom info...
detection phase #1...
detection phase #2...
warning: rom info information not found, possible reasons:
.old firmware type w/o rom info data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device rom info finished
detect device sec info...
detect device sec info finished
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
.damaged firmware
.damaged hardware
ffs address can not be detected, value from database assigned: 00000000/00000001
startup code area #1 check...
warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.84BE1412.[GINWAVE25_08A_GEMINI_PCB01_GPRS_MT6225_S00.FXD-H1_01_V1_0_023_090518.BIN_8AE45914].rpl
warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.84BE1412._GINWAVE25_08A_GEMINI_PCB01_GPRS_MT6225_S00.FXD-H1_01_V1_0_023_090518.BIN_8AE45914_.rpl
warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.84BE1412.[GINWAVE25_08A_GEMINI_PCB01_GPRS_MT6225_S00.FXD-H1_01_V1_0_023_090518.BIN_8AE45914].rpl
warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.84BE1412._GINWAVE25_08A_GEMINI_PCB01_GPRS_MT6225_S00.FXD-H1_01_V1_0_023_090518.BIN_8AE45914_.rpl
warning: unknown rom info structure: GINWAVE25_08A_GEMINI_PCB01_GPRS_MT6225_S00.FXD-H1_01_V1_0_023_090518.BIN_8AE45914
error: Unknown firmware detected (v.2.91, database date: ), user action required:
1. download latest software from support area and try again
2. if no still luck follow the next procedure:
- find good working phone with the same firmware:
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
- be little bit patient and wait update
error: startup code area #1 can't be fixed
detecting startup code area #2...
startup code area #2 is absent
Area: Firmware
Write: Firmware
Write Done
Finalization ...
Finalization Done
Finished, time used: 2047 sec
Remove/Install battery now !
CHECK HERE FULL LOG FILE NOT SAVE IN ANY RAR OR ZIP
BR.DYNET
Old 09-02-2009, 12:33   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
please send flash file to [email protected]
i will check what is wrong with it
Old 09-03-2009, 07:50   #5 (permalink)
DYNET's Avatar
Member: 320363
Sonork: 100.1578853
Thanks Meter: 3,938
http://rapidshare.com/files/27499736...3048.B0M..html
Old 09-03-2009, 16:55   #6 (permalink)
Member: 148515
hello!
thank you, downloaded.
Need unlock code for VDF136 new firmware here is dump. azeem781986 FuriousGold 16 05-26-2010 04:48
BB5 Simlock RPL Here Some Important Parts [Discussion Here] Ron2pet Genie Universal 3 01-13-2010 08:01
mr. Lead plesa look at here.. important... saidgoren Cruiser Suite 3 11-14-2006 16:37
Important!!! Read here before start to use UST Pro !!! VsH-GsM UST Pro II 38 03-23-2004 10:23
Read Here !!!!!!!!! Important !!!!!!!! VsH-GsM UST Pro II 7 02-04-2004 18:54
Page generated in 0.20576 seconds with 10 queries
