02-19-2009, 08:51 | #2 (permalink) |
No Life Poster Join Date: Mar 2008 Location: infinity-box
Member: 720034 Status: Offline Thanks Meter: 213 | Hello, 1. C:\Program Files\InfinityBox\Documentation\ChineseMiracle 2. How to write flash (upgrade/downgrade firmware, change language): 1. connect cable 2. run "Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable 2. run "Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not wrks try to make "complete" format (if this option exist) 1. connect cable 2. run "Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software |
can i flash chaina mobile | maanarman | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 0 | 09-30-2009 17:19 |
whats best flux to use and where to get it in the UK? | The Repair Shop | Hardware Equipments for GSM | 0 | 08-06-2009 09:26 |
How to use and how to flash chaina mobiles with spider man i am just new | mobilecitycbk | SpiderMan | 2 | 02-19-2009 12:56 |
How to use CPF BOXII to identify pin and CPU of iphone A6 | scngsc | CPF-BOX Ⅱ | 3 | 09-16-2008 16:34 |
How to use EMMA II to flash P800 | shankqiu | Sony Ericsson | 0 | 12-12-2003 21:24 |
