05-20-2009, 19:25 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: egypt Age: 45
Member: 155242 Status: Offline Thanks Meter: 136 | hi all infinity team phone stell not support yet i read flash frome the phone as kp 210a please add this phone to infinity soft KP170 br |
The Following 2 Users Say Thank You to adriano II For This Useful Post: |
05-21-2009, 10:21 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, try to use this software for unlock: http://www.infinity-box.com/download..._LgA_v1.39.rar Waiting for your results |
05-21-2009, 12:41 | #3 (permalink) |
No Life Poster Join Date: Nov 2005 Location: romania
Member: 201764 Status: Offline Thanks Meter: 76 | hy HY, I have try to unlock this phone but after unlock phone was still locked.Here is log: module v1.39 Device: LG-KP170 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: enhanced Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E223C2200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb id: 00005283 Boot Done Set baud ... 921600 Set baud Done Check flash ... current eeprom imei: 350305260000001 file saved: C:\Program Files\InfinityBox\LgA\eeprom_350305260000001_LG-KP170_20090521-143408.B1E.bin .................................................. .............. Check flash Done Check space ... current eeprom imei: 350305260000001 Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 37 sec Remove/Install battery now ! Thys log is for ENHANCED method,but whit standard method this is log: COM55 [VCP0] selected module v1.39 Device: LG-KP170 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E223C2200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb id: 00005283 Boot Done Set baud ... 921600 Set baud Done Check flash ... current eeprom imei: 350305260000001 file saved: C:\Program Files\InfinityBox\LgA\eeprom_350305260000001_LG-KP170_20090521-143850.B1E.bin .................................................. .............. Check flash Done Check space ... current eeprom imei: 350305260000001 .................................................. .............. finalization done Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 56 sec Remove/Install battery now ! What should i do next to unlock whit infinity?Tnks in advanced |
The Following User Says Thank You to raltelefonica For This Useful Post: |
05-21-2009, 13:11 | #4 (permalink) |
Member: 201764 Status: Offline Thanks Meter: 76 | hy, Now is a litle problem,after unlock phone dont have a network neither whit original sim .What should i do to repair network for this phone.tnks in advanced |
05-21-2009, 14:04 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Thanks for test ! Flash phone with original eeprom backup, phone should be in it's original state. We will try to check ASAP what is the problem with unlock. |
05-21-2009, 17:05 | #6 (permalink) |
Member: 155242 Status: Offline Thanks Meter: 136 | sorry i can't try becose i unlocked my phone with Furious but when i do unlock with select kp210 the phone comblet unlock but the phone stell locked COM6 [VCP0] selected module v1.38 Device: LG-KP210A Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E223C2200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb id: 00005283 Boot Done Set baud ... 921600 Set baud Done Check flash ... current eeprom imei: 350305260000001 file saved: C:\Program Files\InfinityBox\LGA\eeprom_350305260000001_LG-KP210A_20090520-201639.B1E.bin .................................................. .............. Check flash Done Check space ... current eeprom imei: 350305260000001 .................................................. .............. finalization done Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 58 sec Remove/Install battery now ! |
Hi polar team Hi all? [WELCOME] | kcsystems | PolarBox 3 | 2 | 11-18-2009 15:46 |
All infinity team very importent | AY29!4LYF | Infinity-Box | 2 | 02-23-2009 18:53 |
hi all infinity team | RaSkAl01 | Infinity-Box | 1 | 04-12-2008 10:50 |
hi infinity team plz help ... | unlock_solution | Infinity-Box | 0 | 04-08-2007 20:01 |
