11-22-2014, 18:25 | #1 (permalink) |
Freak Poster Join Date: Apr 2013 Location: Android
Member: 1916900 Status: Offline Sonork: .::NIGAM::. Thanks Meter: 81 | hi infinity team pls add this flash ic support see log Chinese Miracle II [MTK module] v 1.06 Operation : Check / Read Info [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 24 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 009800BC009000660076001600080000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 Configure emi settings DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1 [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done Erased phone or unsupported FlashIc? Done! Elapsed: 00:00:11 Reconnect Power/Cable! Operation : Read Flash [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 19 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 009800BC009000660076001600080000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1 [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... NAND settings not exists, will check now ... Settings read Ok! - > Re-connect battery and start operation again! Done! Elapsed: 00:00:14 Reconnect Power/Cable! Operation : Read Flash [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 19 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 009800BC009000660076001600080000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1 [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Read Ok , collect info MTKxCPU : MT6572 Saved to : C:\InfinityBox\CM2MTK\Flash\MT6572.ispff Done! Elapsed: 00:03:33 Reconnect Power/Cable! this is working phone i am just testing read info/formet working or not and pls improve imei writing not working i have checked |
11-22-2014, 20:18 | #2 (permalink) |
Member: 1916900 Status: Offline Sonork: .::NIGAM::. Thanks Meter: 81 | full flash readed from phone :- https://forum.gsmhosting.com/vbb/****************************/?4q17806zzbjexig |
11-23-2014, 16:10 | #4 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Probably, from next version will be added "Self-Learning" algo to make all flash ic supported. Check all collected dumps and making something for them. |
The Following User Says Thank You to Dzirt For This Useful Post: |
11-26-2014, 17:09 | #5 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | If someone have NAND phone with such log - PM me to obtain test exe. P.S. - no need asking test versions just for fun, if I not receive log after - you will be in black list after - mean no acess to future CM2 updates. |
11-26-2014, 18:14 | #6 (permalink) |
Freak Poster Join Date: Sep 2007 Location: algeria Age: 35
Member: 580077 Status: Online Sonork: 100.1591941 Thanks Meter: 207 | like this ? Code: Operation : Check / Read Info [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 120 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x006A , [MICRON] MT29F1G16ABB [NAND] : FLASH_DIE : 00EC 00BC 0000 0055 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Done! Elapsed: 00:00:07 Reconnect Power/Cable! |
11-26-2014, 18:54 | #7 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | nori2007, no, I mean : Code: Boot Ok! Info read not done Erased phone or unsupported FlashIc? Done! MT6575/MT6577 NAND fix ready, will be in next. |
The Following 3 Users Say Thank You to Dzirt For This Useful Post: |
11-26-2014, 21:05 | #9 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Probably - will finish new exe tomorrow for public use, just was interest to check something now. |
The Following 2 Users Say Thank You to Dzirt For This Useful Post: |
