Old 06-01-2007, 08:48   #1 (permalink)
Member: 141547
Thanks Meter: 3
HI infinty taem
i have prplem for f3 20 pic ded after falch disbly on wohtit batry
plz help me
Old 06-01-2007, 10:32   #2 (permalink)
Member: 148515
Thanks Meter: 14,904
hello!
Dispaly is always ON without battery.
this is a specific of it work. this is energy saving Display.
can you post log for flashing this phone?
Old 06-02-2007, 14:46   #3 (permalink)
Tamer_Elhosary's Avatar
Member: 63774
Sonork: 100.88137
Thanks Meter: 133
i have the same wait your help
Old 06-02-2007, 14:56   #4 (permalink)
Member: 148515
hello!
which same? phone dead or display always ON even without battery?
post here a flashing log
Old 06-03-2007, 14:33   #5 (permalink)
Member: 63774
Sonork: 100.88137
Thanks Meter: 133
have 50 pcs phone dead
Old 06-03-2007, 16:02   #6 (permalink)
Member: 128745
Thanks Meter: 16,850
i have already asked you to flash using slower speed ... waitin for results
Old 06-03-2007, 20:23   #7 (permalink)
Member: 63774
Sonork: 100.88137
Thanks Meter: 133
hi bro
i try with it and cant flash
Old 06-03-2007, 20:40   #8 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
@Tamer_Elhosary
If you want to get help you must explain your problem so detailed as possible.
What to do if you don't understand what to do:
1. use fully charged battery !!!
2. use correct files (the same version firmware and LP)
Old 06-05-2007, 13:06   #9 (permalink)
Member: 63774
Sonork: 100.88137
Thanks Meter: 133
@InfinitySupport
i flash more than 2000 pcs and only 50 pcs stoped
Infinity Box
1.01 k-module
Moto-F3_Main_R3T621_G_15.18.12R.A8M
Moto-F3_LP_Flex_R3T621_G_15.18.12R_GSDTNGO000HG00164034 _En_FR_AR.A8P
COM11 selected
Device: Motofone F3
Checking data, wait...
Action: Flash write
Write: Firmware
Skip: Customization
Write: Language Pack
Skip: Eeprom
Connect...
Phone must be POWERED-ON !
connect stage #1...
connect stage #1 fail
connect stage #1...
Connect Fail
Finished, time used: 20 sec
Remove/Install battery now !
Old 06-05-2007, 19:08   #10 (permalink)
Member: 130995
@Tamer_Elhosary
I don't understand what is the problem ?
please, explain the problem so I can read and will try to understand what is wrong. It's really funny when I try to understand the problem but user even did not tried to make problem description already several days.
for your info:
it's not possible to kill F3 permanently during flashing
if you have phone that can't power-on you must check phone battery,check phone hardware and you can try to use "emergency connection mode" (see "settings" page in software).
Old 06-05-2007, 19:27   #11 (permalink)
Member: 63774
Sonork: 100.88137
Thanks Meter: 133
the problem phone cant flash and cant switch on
phone battery ok and can switch on other phone
hardware phones new and work fine befor flash
i will try with emergency connection
wait me
Old 06-05-2007, 19:34   #12 (permalink)
Member: 63774
Sonork: 100.88137
Thanks Meter: 133
do it with emergency connection
my greeting 2 you bro
thx for fast help and gr8 support
Old 06-05-2007, 19:57   #13 (permalink)
Member: 130995
glad to hear about good results. "emergency mode" should be used if phone was flashed with wrong firmware or flash process terminated due to low battery etc.
can infinty informe me if possible ayoub_gsm Infinity-Box 2 03-29-2010 15:25
hi infinty support please upload my flash file ysraeldark Infinity-Box 1 01-28-2010 19:51
hi infinty team se odm update sahbettin Infinity-Box 1 08-16-2009 22:37
hi infinty team i have very new model help dark20054 Infinity-Box 3 08-09-2007 21:10
Page generated in 0.35999 seconds with 8 queries
