06-03-2014, 18:15 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Do you need this file or you want to upload this file for us ? |
06-03-2014, 20:59 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, All flash files that we have already uploaded in Infinity-Box support area. Please login to support area and download files there. Also if you request flash files here I suggest you to write here required firmware version. It's quite hard to find flash file just by phone photo |
06-04-2014, 03:57 | #5 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | For start - read firmware with CM from it. Show us : logs and upload dump. Also - it dead not with CM , because our software not kill phones |
The Following 2 Users Say Thank You to Dzirt For This Useful Post: |
06-04-2014, 07:56 | #6 (permalink) |
No Life Poster Join Date: Aug 2011 Location: Algeria is a North African Age: 35
Member: 1629321 Status: Offline Thanks Meter: 823 | gx-i9500 SPRD gx-i9500 SPRD Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.2 CPU TYPE:SC6531 [65310000] FLASH ID: 00EF006000180000 Size:0x1000000(16MB) the phone has dual-flash ic,it reads flash size actually32(M) Reading completed. >>The data has been saved in C:\Documents and Settings\hhuoi\Bureau\MOCOR_12B_6531.W13.07_Releas e_20131126_150519_FullFlash.bin, size: 32 M. the phone has dual-flash ic,it reads flash size actually32(M) |
The Following User Says Thank You to bencharqui1 For This Useful Post: |
06-04-2014, 11:07 | #8 (permalink) | |
If you want to get support from The Great Infinity Team you must be Infinity user. So at first post here operation log with Infinity software and only then you can ask for a help. | |
06-04-2014, 14:30 | #9 (permalink) |
Member: 1629321 Status: Offline Thanks Meter: 823 | I use the Infiniti, but the problem in writing many of the Firmware on the phone and bad information Card found: S/N B38F:0126 |
06-04-2014, 15:09 | #10 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello , if CM2SPD say - bad file that mean file is really bad and can't be flashed. Can you read fw from phone? If you not flash it yet , sure. Otherwise it will not give any good result. Read only with CM2SPD , other can give and sure, will give wrong result. |
The Following User Says Thank You to Dzirt For This Useful Post: |
06-04-2014, 15:44 | #11 (permalink) |
Member: 1629321 Status: Offline Thanks Meter: 823 | Gives the wrong result all try flash gives wrong result and the original information from the first day of work before Foramt CPU TYPE:SC6531 [65310000] FLASH ID: 00EF006000180000 Size:0x1000000(16MB) the phone has dual-flash ic,it reads flash size actually32(M) Reading completed. >>The data has been saved in C:\Documents and Settings\hhuoi\Bureau\MOCOR_12B_6531.W13.07_Releas e_20131126_150519_FullFlash.bin, size: 32 M. |
06-04-2014, 16:26 | #12 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | You still post unknown for me logs. If you not made backup from phone before write inside it some piece of china code - forget about this phone. If you not want next time that headache - recommend you use Infinity. Because our solutions not kill phones. |
