Old 05-31-2008, 15:09   #1 (permalink)
Registered User
eko_java_cell's Avatar
Member: 347872
Thanks Meter: 5
Hi-tech H38 dead need find firmware
Hello infinity team I have Hitech H38 dead I read full flash N i need firmware for this phone correctly This is backcasing imei:
HI-TECH H38
Imei : 356889007760851
S/n :L07600776089
READ FULL FLASH :
backup_flash[BR26_05C_PCB01_GPRS_MT6226_S01.BR26_35_49.BIN]_20070601-091316.B0M
Old 05-31-2008, 16:47   #2 (permalink)
Registered User
Member: 347872
Thanks Meter: 5
i try to flash with search in support area but still same dead this is Log flash N format Ffs :
COM4 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: erase flash chip
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:6F6E503
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:29EA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
921600
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.5C01296D.[BR26_05C_PCB01_GPRS_MT6226_S01.BR26_35_49.BIN_382C 7215].rpl
identification#1 detection finished
device-id: 5C01296D
identification#1 protocol ver: 04
ver. sw1: BR26_05C_PCB01_GPRS_MT6226_S01.BR26_35_49.BIN
ver. sw2: BR26_35.49, EA8DD3C7
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading [eeprom[BR26_05C_PCB01_GPRS_MT6226_S01.BR26_35_49.BIN]]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[BR26_05C_PCB01_GPRS_MT6226_S01.BR26_35_49.BIN]_20080531-114012.B0E.bin
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Erase: chip 1 of 1
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_5C0129 6D_BR26_05C_PCB01_GPRS_MT6226_S01.BR26_35_49.BIN_3 82C7215_20080531-114210.B0X.bin
Finished, time used: 307 sec
Remove/Install battery now !
Old 05-31-2008, 17:22   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
What was the reason to make "erase flash chip" ?
Now you must flash phone with firmware from support area !
Old 05-31-2008, 19:11   #4 (permalink)
Registered User
Member: 347872
Thanks Meter: 5
i flash many time but still can power On,Ok i will write flash N post result.
Old 05-31-2008, 19:19   #5 (permalink)
Registered User
Member: 347872
Thanks Meter: 5
after i write flash phone Blank N vibrating,Whats problem???
This Log flash :
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
write: Eeprom/ffs
Boot...
19200 fixed
Connecting, wait...
CPU: MT6226
chip: 0031:6F6E503
high speed disabled
Boot Done
Initialize...
flash: EC257E25082501:FFFFFF00000000
Initialize Done
Set baud...
921600
Set baud Done
Warning: probably flash chip empty, erased, incorrectly flashed or damaged.
What to do:
1. go to software "Settings" page
2. set "Advanced chip detection method" box UN-CHECKED !
3. make flash write operation
If still no luck: send mail to support ([email protected]) with detailed description of problem,
attach the next files in your e-mail:
1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log
2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_***x_***x.bin
it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
standard eeprom/ffs offset assigned: 00E00000
Can't detect eeprom/ffs area
Do you want to use standard ffs address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs address selected by user
ffs chip: 00
reading [eeprom]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom_20080531-140816.B0E.bin
Write...
.damaged firmware
.damaged hardware
security area#1 calculation...
done
Area: Firmware
Write: Firmware
Area: Eeprom/ffs
Write: Eeprom/ffs
Write Done
Finalization...
Finalization Done
Finished, time used: 656 sec
Old 05-31-2008, 22:34   #6 (permalink)
Member: 130995
This means that you need to write another firmware that will be more suitable for your phone.
Old 06-01-2008, 09:09   #7 (permalink)
Registered User
Member: 347872
Thanks Meter: 5
you can help me to find another firmware suitable for my phone???
Old 06-01-2008, 12:07   #8 (permalink)
Member: 130995
Yes, sure.
You can download many different files from Infinity-Box support area. So just make "search" in support area by firmware name or by model name and you will find required file.
Hi-tech HT- 200 flashfile needed Riteshgpt60 SpiderMan 4 03-29-2011 12:29
Need Fimwares Hi-Tech H63 megdy SpiderMan 0 06-22-2009 12:01
Need Fimwares Hi-Tech H63 megdy CPF-Dongle 0 06-22-2009 11:47
Hi-tech H38 dead lcd after flash eko_java_cell Infinity-Box 3 06-08-2008 12:14
Hi Tech H38 Kiraran Infinity-Box 1 05-07-2008 20:22
Page generated in 0.23756 seconds with 9 queries
