03-21-2009, 21:14 | #1 (permalink) |
No Life Poster Join Date: May 2007 Age: 42
Member: 501674 Status: Offline Sonork: THEIF OF HEART Thanks Meter: 883 | KP320 flashing error WHAT IS REASON infinity team i try to all speed 115200.and all boud .but same problem KP320-00-V10f-CIS-XX-JUL-01-2008_A7610_07A_PCB03_GPRS_MT6229_S02.7S7610RU00-001-R1Y_En_Ru_Kz.B4M COM5 [VCP0] selected module v2.68 Device: LG-KP320 Checking data, wait... Action: write NAND flash read mode: 01 write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs source data: page only identification#1 protocol ver: 04 ver. sw 1: A7610_07A_PCB03_GPRS_MT6229_S02.7S7610RU00-001-R1Y.BIN ver. sw 2: 7S7610RU00-001-R1Y, 00000000 ffs offset/size: 02000000/06000000 id-page1 Ok end mark #4 found nfi area detection finished: Ok Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6229:8A02:8A02]... CPU: MT6229 chip: 0031:200B:0101 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.0209 loader: 3.748.0 NAND id: 98F19095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 NOR: 0000:000000000000 [00000000] NAND: 0098:00F100900095 [08400000] NOR chip is not installed Initialize Done Set baud ... 115200 Set baud Done Identification ... reading bootloader structure area... detecting bootloader structure... warning: probably flash chip completely erased, no bootloader found nfi area detection finished: failed warning: can't detect nand chip parameters, default values assigned Identification Done Write ... error: unexpected answer: error: incorrect write core parameters error: can't write nand core Write Fail Finished, time used: 92 sec Remove/Install battery now ! sajid..... |
03-22-2009, 19:11 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Try to make this: 1. download test software: http://www.infinity-box.com/download...9_for_test.rar 2. select model "6228-6230 NAND" 3. flash your phone with KP320 flash file waiting for your results |
11-02-2009, 18:29 | #7 (permalink) |
No Life Poster Join Date: Nov 2006 Location: *P*A*K*I*S*T*A*N
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | rehot oar reball your flash chip.. mostly these CPU encounter such errors |
The Following User Says Thank You to StRaNgE PeRsOn For This Useful Post: |
11-16-2009, 06:58 | #8 (permalink) |
Freak Poster Join Date: Jul 2007 Location: ctg ,bangladesh Age: 42
Member: 538272 Status: Offline Sonork: 100.1589159 Thanks Meter: 71 | lg kp320 restart problem solved tested today i m tested best of luck |
The Following User Says Thank You to Palash Telecom_ctg For This Useful Post: |
what is this infinity team?????????????/ | shamshad quresh | Infinity-Box | 9 | 11-02-2009 18:00 |
what is reason this error in my box | REZAMAHMOODI | Universalbox | 2 | 04-03-2007 09:25 |
what is this sc team ware is chi mei option and ware is imode option | rajabrotherscom | Smart-Clip | 14 | 02-16-2007 00:25 |
what is this fg team vk200 vk4000 totaly free | rajabrotherscom | FuriousGold | 0 | 02-14-2007 08:42 |
WHaT iS THiS @ FURIOUS TEAM???????? | .::BHATTI::. | FuriousGold | 16 | 11-25-2006 09:23 |
