hisense f20 how to send into edl mod via tp 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Connect device in fastboot mode ... Connect Ok! Trying set EDL mode ... If device not reboot in EDL - use KEYS combination/EDL cable/TP Operation finished! |
EDL >> Press VOL - key and connect Deep flash cable |
try via both booth press same time try via vol up try via down these tricks fail deep flash cabal what means me normal usb cabal |
yes via vol down and from usb gnd and d+ short for 8 second and job done ya hisense f20 done Operation : Read Flash [ v1.13 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 01539F7F ID_BLOCK_I : 009600E1 ID_BLOCK_L : 04FC9660CF5B40433C11E3EC2B76FECE ID_BLOCK_L : 0E45CB6257FE60E518D7B87173B2ACAF Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001C3000000 [ eMMC 8 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000/00000200 Boot Ok! Brand : Hisense ProdName : F20AE-2 ProdModel : Hisense F20 Device : F20AE-2 AndroidVer: 5.1.1 Manufact. : Hisense QLMxCPU : MSM8909 QLMxPRJ : L1236.6.01.01.AE00 DevInfo : MSM8909__Hisense__Hisense__ANDR_v5.1.1__Hisense_F2 0__F20AE-2__F20AE-2__L1236.6.01.01.AE00 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : sbl1.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : misc.img [Read Ok] : diag.bin [Read Ok] : lsplash.img [Read Ok] : NON-HLOS.bin [Read Ok] : sec.dat [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : persist.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8909 / eMMC Firmware Size : 2192 MiB Done! Elapsed: 00:05:10 Reconnect Power/Cable! |
I try this firmware but stuck in userdata.img 9% or HLOS in 46%, its prob hardware problem..? |
And screen shot |
and phone work fine |
