Old 06-15-2017, 12:11   #1 (permalink)
Member: 1197620
Sonork: 100.1602278
Thanks Meter: 599
hisense f20 how to send into edl mod via tp
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device not found!
Check cable, connection and drivers!
Reconnect Power/Cable!
Connect device in fastboot mode ...
Connect Ok!
Trying set EDL mode ...
If device not reboot in EDL - use KEYS combination/EDL cable/TP
Operation finished!
Old 06-15-2017, 12:21   #2 (permalink)
.::EXTREME::.'s Avatar
Member: 1619462
Sonork: 100.1606509
Thanks Meter: 1,507
EDL >> Press VOL - key and connect Deep flash cable
The Following 3 Users Say Thank You to .::EXTREME::. For This Useful Post:
Old 06-15-2017, 13:53   #3 (permalink)
Member: 1197620
Sonork: 100.1602278
Thanks Meter: 599
suddenly reboot and power on some time go in update mode
try via both booth press same time
try via vol up
try via down
these tricks fail
deep flash cabal what means me normal usb cabal
Old 06-15-2017, 15:55   #4 (permalink)
Member: 1197620
Sonork: 100.1602278
Thanks Meter: 599
yes via vol down and from usb gnd and d+ short for 8 second and job done
ya hisense f20 done
Operation : Read Flash [ v1.13 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 210 [MSM8x09]
ID_BLOCK_S : 01539F7F
ID_BLOCK_I : 009600E1
ID_BLOCK_L : 04FC9660CF5B40433C11E3EC2B76FECE
ID_BLOCK_L : 0E45CB6257FE60E518D7B87173B2ACAF
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000001C3000000 [ eMMC 8 GiB ]
ExtInfo : 0x0000C000/00100000/00001000/00001000/00000200
Boot Ok!
Brand : Hisense
ProdName : F20AE-2
ProdModel : Hisense F20
Device : F20AE-2
AndroidVer: 5.1.1
Manufact. : Hisense
QLMxCPU : MSM8909
QLMxPRJ : L1236.6.01.01.AE00
DevInfo : MSM8909__Hisense__Hisense__ANDR_v5.1.1__Hisense_F2 0__F20AE-2__F20AE-2__L1236.6.01.01.AE00
Reading Flash Content ...
[Read Ok] : gpt_main0.bin
[Read Ok] : sbl1.mbn
[Read Ok] : emmc_appsboot.mbn
[Read Ok] : rpm.mbn
[Read Ok] : tz.mbn
[Read Ok] : misc.img
[Read Ok] : diag.bin
[Read Ok] : lsplash.img
[Read Ok] : NON-HLOS.bin
[Read Ok] : sec.dat
[Read Ok] : boot.img
[Read Ok] : system.img
[Read Ok] : persist.img
[Read Ok] : cache.img
[Read Ok] : recovery.img
[Read Ok] : userdata.img
[Read Ok] : gpt_backup0.bin
Android Info saved!
Read finished!
Configuration : MSM8909 / eMMC
Firmware Size : 2192 MiB
Done!
Elapsed: 00:05:10
The Following User Says Thank You to saleem5001 For This Useful Post:
Old 08-05-2017, 12:11   #5 (permalink)
alwi7666's Avatar
Member: 368730
Thanks Meter: 179
I try this firmware but stuck in userdata.img 9% or HLOS in 46%, its prob hardware problem..?
Old 08-05-2017, 12:34   #6 (permalink)
Member: 1197620
Sonork: 100.1602278
Thanks Meter: 599
Post here logs
And screen shot
Old 04-02-2019, 11:24   #7 (permalink)
Member: 136052
Thanks Meter: 73
im write thisi adrdres from yasy jtag then write firmware without thise
and phone work fine
Page generated in 0.28200 seconds with 7 queries
