11-20-2018, 02:53 | #3 (permalink) |
Freak Poster Join Date: Oct 2013 Location: asia
Member: 2038233 Status: Offline Thanks Meter: 7 | Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 625 [MSM8953] ID_BLOCK_S : 3A29E917 ID_BLOCK_L : 3770D3CF7D74BCFF96EA7631A511E9EE ID_BLOCK_L : F30D67DE11382A00FF4E8B7EF96DB9EC Use CM2 Internal Loader FH_LOAD_CODE : 15 ERROR : Loader send failed! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 625 [MSM8953] ID_BLOCK_S : 3A29E917 ID_BLOCK_L : 3770D3CF7D74BCFF96EA7631A511E9EE ID_BLOCK_L : F30D67DE11382A00FF4E8B7EF96DB9EC Use CM2 Internal Loader FH_LOAD_CODE : 15 ERROR : Loader send failed! HINT : Check cable, connection and drivers! Reconnect Power/Cable! i think driver is good,cz other device qlcom chip no problem |
