Old 03-11-2016, 06:58   #1 (permalink)
Member: 430612
Thanks Meter: 262
hisense u939 flashing failed
Card found : S/N : 5B4F6FE4 , v0130
Chinese Miracle II [MTK module] v 1.43
Load File
File_Info : u939e_4
FileVersion : MT6572
Load File Ok
Operation : Flash [ v1.43 ]
======= Flash
Files set for flashing :
[ MCU ] : MT6572__HISENSE__HS-U939__W864.6.06.01.ZA00__Android_4.2.2.ispff
Wait for phone...
Phone found! [ 69 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4834473164048601A38A63A045
Initialize Memory ...
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164048601A38A63A045
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID : 532E27EA7F53AF8FB5B1B492B16841B7
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Brand : Hisense
ProdName : u939e_4
ProdModel : HS-U939
Device : u939e_4
AndroidVer: 4.2.2
MTKxCPU : MT6572
MTKxPRJ : W864.6.06.01.ZA00
ISPFF ID : 6572 , TARGET ID : 6572
FlashFile is differs from eMMC settings, continue by user request
Flash pre-erase enabled
Erase Flash now ...
Flash pre-erase done
Write Flash now ...
Init Ok , Sending blocks ...
Write failed
Flash Error!
Check Cable, Battery , try again
Operation Failed
Elapsed: 00:01:43
Reconnect Power/Cable!
i had 2 phones same model 1 came right and this on refuse to flash now is no more hang is totally dead plz help to recover it.i press flash erase button
Old 03-11-2016, 07:23   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,544
Use Factory FW instead of dumps. FW can be read with tick "Factory FW'".
Old 03-11-2016, 09:29   #3 (permalink)
Member: 430612
Thanks Meter: 262
still the same even with tick FW
Operation : Read Flash [ v1.43 ]
Wait for phone...
Phone found! [ 52 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A4834473164040501A18A9561F1
[eMMC] : FLASH_CID : 90014A4834473164040501A18A9561F1
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 21C2B3C6A5CEBB303D1D6AB19DFCADC5
SOC VERIFY : C1
Boot Ok!
Reading Flash Content now ...
Brand : Hisense
ProdName : u939e_4
ProdModel : HS-U939
Device : u939e_4
AndroidVer: 4.2.2
MTKxCPU : MT6572
[Read Ok] : preloader_u939e_4.bin
[Read Ok] : MBR
[Read Ok] : EBR1
[Read Ok] : lk.bin
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : secro.img
[Read Ok] : logo.bin
[Read Ok] : system.img
[Make Ok] : cache.img
[Make Ok] : userdata.img
[ScatCFG] : MT6572 / V1.1.1 / u939e_4 / EMMC
Android Info saved
HWConfig Info saved
FW Size : 681 MiB
Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6572__Hisense__HS-U939__u939e_4__4.2.2__W864.6.06.01.ZA00\
All done!
Done!
Elapsed: 00:04:45
Load File
Bad file detected!
Scatter Load Ok , BaseBand : MT6572 , Project : u939e_4 , Storage : EMMC
Files found : 11 , Set to Flash : 10
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand : Hisense
Device Model : u939e_4
Device CPU : MT6572
Device IntName : u939e_4
Device Version : 4.2.2
Device Compile : 12/25/2014 9:37:19 AM
Device Project : W864.6.06.01.ZA00
Device ExtInfo : HS-U939
Ready to Flash!
======= Flash
Wait for phone...
Phone found! [ 49 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
DRAM configured from ScatFW!
DRAM initialize passed!
DRAM size : 0x20000000
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : u939e_4 , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
Switching to HSUSB
HSUSB Init Ok
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3741 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000002900000-0x00000000E2700000
Flash Pre-Erase Done, time used : 00:00:22
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_u939e_4.bin
Preloader Sent , Init passed
PartCount : 0013
Update PMT by user request
Repartition Failed! Break! Something wrong with HW or BL (FirmWare)
Operation Failed
Elapsed: 00:01:24
Old 03-11-2016, 09:43   #4 (permalink)
JayDi's Avatar
Member: 462970
Now check for ReadOnly ( Extra - Make test with selected FlashIC )
if Test Ok - erase and reflash. If not change eMMC Ic.
Old 03-11-2016, 10:48   #5 (permalink)
Member: 1469250
Sonork: 100.1662168
Thanks Meter: 75
Exclamation Hmmm....
Dear JayDi
I Think The Problem Is In File! That He Readed
Coz Read Flash Info Check, The CM2 Saying!
"Bad File Loaded"
Bcoz He Readed Faulty Firmware or The File Is Not Good
If He Try To Read Firmware From Alive Phone
Then Flash On Bad Phone...!
Problem Will Be Solved, Also Change USB-Cable & Port
I Many Time Kick "PhData Erro" When Reading Firmware
by Changing USB Cable.
NAsiR_TaNK
KxNTeam
Page generated in 0.27312 seconds with 7 queries
