Old 03-29-2019, 13:21   #1 (permalink)
Member: 64823
Thanks Meter: 439
HISENSE U965 FRP failed !
I tried to make FRP but always failed:
Card found : S/N : 03EC4A8A , v0137
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 36 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 150100464E36324D42033FE3D693844D
Initialize Memory ...
[DA_ERROR] : DRAM Configure failed!
ErroCode : 0x2003
EMICFG_NOT_FOUND
TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT!
Boot Error!
Operation Failed
Elapsed: 00:00:12
Reconnect Power/Cable!
Wait for phone...
Phone found! [ 36 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
ErroCode : 0x2003
EMICFG_NOT_FOUND
Boot Error!
Operation Failed
Elapsed: 00:00:03
Wait for phone...
Phone found! [ 36 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
ErroCode : 0x2003
EMICFG_NOT_FOUND
Boot Error!
Operation Failed
Elapsed: 00:00:08
Wait for phone...
Phone found! [ 34 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
[DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED
Boot Error!
Operation Failed
Elapsed: 00:00:03
Old 03-29-2019, 13:53   #2 (permalink)
Member: 2807070
Sonork: 550000
Thanks Meter: 37
it is signed base phone use special da agent for this phone to remove frp
Old 03-29-2019, 13:55   #3 (permalink)
Member: 64823
Thanks Meter: 439
Can you help where to get these SPECIAL DA ?
Old 03-29-2019, 14:02   #4 (permalink)
Member: 2807070
Sonork: 550000
Thanks Meter: 37
give me your email address or open your msg privicy i sent you link
Old 03-29-2019, 16:22   #5 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
Best solution to Use MT2 2.05 for different built-in DA Files & advanced features.
If fails you can use Custom DA Easily.
Old 03-29-2019, 19:01   #6 (permalink)
Member: 64823
Thanks Meter: 439
Mt 2.05 does not opened ! I reinstall still not opening.. what is the ISsue?
Old 03-29-2019, 19:22   #7 (permalink)
Member: 64823
Thanks Meter: 439
Hello. i tried... still FRP here !!
Card found : 03EC4A8A , v0137
Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.05
Load IDBase v123080 Ok!
Operation : Identify [ v2.05 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM5)
MODE : BOOTROM
PORT : 5
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : LEGACY MTK
BROM : SecLevel : 0x00000000
BROM : SecMode : PLAIN [+PRL]
BROM : BOOTROM
MODE : 0_base : BASE_v1712 | Manual : Disabled
Fail to disable Dog!
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6580
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
NAND : DEVICE NOT FOUND
NAND : 000000000000000000000000
eMMC : OK
eMMC : 460001154D32364EE33F03424D8493D6
DAInf: 4 : 2 : 156
DA : EXT_RAM NOT initialized!
eMMC : OK
eMMC : 150100464E36324D42033FE3D693844D
EMI : DEV : INFINITY
EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0
INIT : 0xBC : LP/DDR3 [ 0x00000000 : [ 0 B ] ]
DRAM : DRAM: 0x40000000 [ 1.00 GB ]
DA : DRAM ready!
DA : BOOT to 2nd DA ...
DA : Receiving HW info
EMMC: 150100464E36324D42033FE3D693844D
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FN62MB
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00080000 [ 512.00 KB ]
USER : 0x1D2000000 [ 7.28 GB ]
SRAM: 0x00020000 [ 128.00 KB ]
CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : EA8CF91162BB52C055355F9BE10F5269
STATUS : BLANK FLASH
BSTYLE : EMMC FLASH BOOT
DA : USB : FULL-SPEED
DA : USB : Change Port Speed
PTFN : MediaTek DA USB VCOM (Android) (COM6)
MODE : PRELOADER PORT
PORT : 6
Boot done!
Patch Level : O11019
Ver. CodeName : REL
Ver. Release : 8.1.0
Sec. Patch : 2018-06-05
Build Time : 1531273211
Display ID : Hisense_U965_00_S05_20180711
Product Model : Hisense U965
Product Brand : Hisense
Product Name : U965
Product Device : HS6580MT
Product Info : HS6580MT
Product Board : Hisense
Product Manfct : Hisense
Product Board : yk737_go_wcdma
Board Platform : mt6580
USERDATA : ENCRYPTED
Done!
Elapsed: 00:00:23
Operation : Reset Settings/Format FS [ v2.05 ]
MODE : BOOTROM
PORT : 5
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 156
eMMC : OK
DA : DRAM ready!
EMMC:
PORT : 6
Boot done!
Format Ok : USERDATA
Format Ok : CACHE
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:29
The Following User Says Thank You to zakiyyboss For This Useful Post:
Old 03-31-2019, 09:08   #8 (permalink)
Member: 64823
Thanks Meter: 439
THE FRP IS NOT REMOVE>> PLEASE HELP
Frp is not Removed Using CM2MT2.... Using MTK app got tother Error posted on other thread..
Old 03-31-2019, 09:13   #9 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Use MemoryTool
Select partition FRP, cache or userdata
Right click - WIPE
Right click - Update partition state.
If there not change anything from BINARY/DATA to EMPTY - then it mostly mean READ_ONLY_EMMC.
The Following User Says Thank You to JayDi For This Useful Post:
Old 03-31-2019, 11:59   #10 (permalink)
Member: 64823
Thanks Meter: 439
Originally Posted by JayDi View Post
Use MemoryTool
Right click - WIPE
i have tried what you explain still the FRP still here !!
Operation : Memory Tool Init [ v2.05 ]
MODE : BOOTROM
PORT : 5
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 156
eMMC : OK
DA : DRAM ready!
EMMC:
PORT : 6
Boot done!
Set default path : C:\Program Files\CM2MT2\phdata\
Ready!
Operation : Erase Memory
Erase selected partitions [3]
[0] Erase partition : FRP
Erase partition Ok!
[1] Erase partition : CACHE
Erase partition Ok!
[2] Erase partition : USERDATA
Erase partition Ok!
Operation finished!
Android Version 8.1.0
Old 03-31-2019, 12:44   #11 (permalink)
JayDi's Avatar
Member: 462970
Android version doesnt matter at all, since there is no OS protection things in this chip implemented.
Its eMMC seems dead.
Page generated in 0.23699 seconds with 9 queries
