11-24-2008, 07:04 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: PANGANDARAN BEACH Age: 44
Member: 427685 Status: Offline Thanks Meter: 103 | HITECH H39 DEAD,repaired ok COM3 [VCP0] selected module v2.69 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:AADA:A9D2 high speed disabled boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.714F72D1.[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B59.BIN_4 F6076A5].rpl identification#1 detection finished device-id: 714F72D1 identification#1 protocol ver: 04 ver. sw 1: U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B59.BIN ver. sw 2: UPU25U26V03B59, 5A899FB0 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:2AEA0000000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: flash[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B59.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\flash[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B59.BIN]_20081124-133439.B0M.bin file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_714F72D1_U26_06B_PCB01_GPRS_MT6226_S01.U PU25U26V03B59.BIN_4F6076A5_20081124-133449.B0X.bin Finished, time used: 774 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [11/24/2008 1:34:56 PM] ==== COM3 [VCP0] selected module v2.69 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:AADA:A9D2 Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 99 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [11/24/2008 1:37:16 PM] ==== COM3 [VCP0] selected module v2.69 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:AADA:A9D2 high speed disabled boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.714F72D1.[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B59.BIN_4 F6076A5].rpl identification#1 detection finished device-id: 714F72D1 identification#1 protocol ver: 04 ver. sw 1: U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B59.BIN ver. sw 2: UPU25U26V03B59, 5A899FB0 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:2AEA0000000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B59.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B59.BIN]_20081124-134052.B0E.bin flash: EC257E25082501:2AEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: EC257E25082501:2AEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_714F72D1_U26_06B_PCB01_GPRS_MT6226_S01.U PU25U26V03B59.BIN_4F6076A5_20081124-134111.B0X.bin Finished, time used: 230 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
need file hitech h39 | alfred_smd | CPF-BOX Ⅱ | 1 | 03-09-2009 03:38 |
VeKing can't find pinout hitech h39 | notgood | VE-KING | 2 | 01-02-2009 20:15 |
HiTech H39 need help | notgood | Infinity-Box | 2 | 08-05-2008 14:04 |
dead V3R repair ok | phonetool | Smart-Clip | 13 | 01-26-2007 02:43 |
