Old 10-26-2007, 15:08   #1 (permalink)
sayyedikram's Avatar
Member: 234349
Thanks Meter: 227
how 2 make oun chinese miracle cable by hand
hi here is the way 2 make oun chinese miracle cable by hand already tested in 30 to 40 hand set sussesfuly
1st u need com cable of moto C115 cut the pin of moto u will get 3 wire white and blue and black in my cable black is ground and white is RX and blue is TX just open the set and find out the RX and TX there is way 2 find out in set RX and TX just put the charger on TX u will find out 1.7 or 2.7 and on RX u will find out 2.8 or 1.8 voltage or just dounload the latested pinout 4rm fourm mostly nokia set u will find on pcb witten on that so its a easy 2 find out RX and TX and connet on infinity dont make format option first just read full flash and its work perfect then 2 desire option
its important 2 find out rx and tx plz make operation veary carefully
use it u r oun risk
thanks
[email protected]
Old 10-26-2007, 17:44   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Here is step-by-step manual for you: http:///vbb/showthread.php?t=433447
Chinese Miracle cable set, where?? armkbdotcom Infinity-Box 34 03-02-2008 11:45
<<<__N73 cable to use with the 29pcs chinese miracle cable?__>>> keaelite Infinity-Box 1 11-04-2007 11:25
Chinese Miracle cable set needed ASAP armkbdotcom Wanted Products 1 01-19-2007 02:55
Page generated in 0.12348 seconds with 9 queries
