Old 03-30-2007, 16:24   #1 (permalink)
polifon's Avatar
Member: 254961
Thanks Meter: 24
Exclamation How about Chinese dual Simcard phones flash files and pinouts?
Can see that models here : http://www.ipmart.com/main/browse.php?&cat=1762
I bought 14 pcs of these phones : http://www.ipmart.com/main/product/A...762&prod=21251
and want write russian lang on it,
for example that phone: http://www.ipmart.com/main/product/Y...tem&prod=19627 have russian lang in menu and both of these models menues absolutely same.
Old 03-30-2007, 19:32   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Read FAQ to see info about cables and pinouts: http://forum.gsmhosting.com/vbb/showthread.php?t=342807
Flash files: please, visit support area.
Old 03-31-2007, 16:26   #3 (permalink)
polifon's Avatar
Member: 254961
Thanks Meter: 24
Sorry but i cant find any pinout/flashfile for this phones.
Just look inside tis phones:
Old 03-31-2007, 22:54   #4 (permalink)
Member: 130995
Hello,
Here is additional information about pinouts:
http://forum.gsmhosting.com/vbb/show...36&postcount=7
Old 04-01-2007, 14:06   #5 (permalink)
polifon's Avatar
Member: 254961
Thanks Meter: 24
How to find pinout for unknown model:
1. find Gnd pin
2. find Charge pins
3. find +Battery pins
4. connect cable Gnd to phone Gnd
5. try to connect cable Rx/Tx wires to all phone contacts one by one (except Gnd, Charge, + Battery) and try to read flash
6. if flash read procedure can start this means that pinout found Ok and you can make other operations
if i have usb cable which came with phone can i get some info about its pinouts?
Old 11-08-2007, 05:24   #6 (permalink)
Member: 364696
Thanks Meter: 16
Plz Need A666 Pinouts
base is same like mentioned above
Old 11-08-2007, 11:42   #7 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
as i see- not much other pins is used in this phone.
you can try all other used pins one by one.
to make brute force more easyer- you can use thin wires soldered to all needed pins,
other wires sides soldered to IC socet. Seting Tx, rx is done by inserting needles toneeded positions
Old 11-10-2007, 18:49   #8 (permalink)
Member: 364696
Thanks Meter: 16
Team I am unable to find pinouts A666
Sir plz help me i am i Neeeeeeeeeeeeeeed Only Pinout
Plz Urgant
http://forum.gsmhosting.com/vbb/atta...0&d=1175433844
i will be thankful
i have try to find pinouts through Team method but unable to find
*spider-man flash files and pinouts "request here"* gsm2start SpiderMan 858 03-17-2012 17:04
All mobiles flash files and pm file and all china pinout and all hardwere solution RIZWANJAT Nokia Hardware & Hardware Repair 4 10-01-2010 10:59
How can i now with wich flash file to flash one chinese phone?? svchost SpiderMan 2 03-25-2010 18:49
Tracvision flash file and pinout plz az_liton Infinity-Box 14 10-30-2008 23:44
need c2000 flash file and pinout nader06 Chinese Models & Cloned Phones 2 08-10-2008 03:43
Page generated in 0.19755 seconds with 10 queries
