06-22-2008, 16:22 | #1 (permalink) |
Freak Poster Join Date: Feb 2008
Member: 713533 Status: Offline Thanks Meter: 18 | how can i find kp130 pinout with auto pinfinder plz help software version: 1.10 cable type: 1x18 (L18B) platform: MT6208 searching adapter at COM8... adapter found, version: 2000 pins: 18, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 115200 fixed 115200 fixed 115200 fixed 115200 fixed 115200 fixed 115200 fixed 115200 fixed 115200 fixed 115200 fixed 115200 fixed 115200 fixed 115200 fixed 115200 fixed 115200 fixed 115200 fixed 115200 fixed 115200 fixed 115200 fixed 115200 fixed 115200 fixed 115200 fixed 115200 fixed 115200 fixed 115200 fixed 115200 fixed 115200 fixed failed to detect pins time required: 46 sec Power Off ! i hhave try with all packages but couldnt plz infinity team help me out |
06-22-2008, 16:57 | #5 (permalink) |
Member: 713533 Status: Offline Thanks Meter: 18 | thank you very much yes i can use other cables but i am using that cable which come with pinfinder adopter and wana make sure if does works or cables are useless plz infinity team i look for yr sujessonthanx |
06-22-2008, 17:02 | #6 (permalink) | |
Product Supporter Join Date: Mar 2005 Location: in CPU
Member: 128745 Status: Offline Thanks Meter: 16,936 | Quote:
You can see pictures in PinFinder manual. Download latest pinfinder manual from http://www.infinity-box.biz/download..._PinFinder.pdf Please, see page 19: Automatic pinout detection: Troubleshooting | |
06-23-2008, 08:51 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @omer100 to find pinout for LG models in automatic mode you need to select ADI CPU type but not MT62xx. Also you can set pinout manually according to this instruction: http:///vbb/showthread.php?t=526956 |
06-23-2008, 12:39 | #8 (permalink) |
Member: 713533 Status: Offline Thanks Meter: 18 | sir i try with adi cpu mode and remove the diot and put cable like in pic still not finding pinout i am doubtfull about l18b cable does i need to modify cables too plz give me some sujessions thanx software version: 1.10 cable type: 1x18 (L18B) platform: ADI: AD6527, 6529 etc. 115200 searching adapter at COM8... adapter found, version: 2000 pins: 18, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... failed to detect pins time required: 22 sec Power Off ! |
06-23-2008, 12:44 | #9 (permalink) |
Member: 128745 Status: Offline Thanks Meter: 16,936 | please make sure you follow steps here , exactly as mentioned ( dont forget , u must use select pinout from list for non chinese phones , do not select Pinfinder ( Automatic ) for non chinese phones) http:///vbb/showpo...08&postcount=1 |
06-23-2008, 13:06 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @omer100 please, try select CPU "ADI: AD6522..." Also here is another way to set pinout for your phone: http:///vbb/showthread.php?t=526956 |
06-23-2008, 13:35 | #11 (permalink) |
Member: 713533 Status: Offline Thanks Meter: 18 | thanx very much for the help sir finally i make unlock kp130 with L18b cable now i am sure i can unlock any non chinese phone with adopter help no need to buy new cables thanx again for chinese phone i can use auto pinfinder to find pinout thanx alot |
06-26-2008, 07:10 | #13 (permalink) |
Freak Poster Join Date: Nov 2002 Location: pondicherry, india Age: 45
Member: 17720 Status: Offline Thanks Meter: 34 | LG KP130 WORKING PINOUT VIA INFINITY PIN-FINDER software version: 1.06 cable type: 1x18 (L18B) platform: ADI: AD6522, 6525, 6526, 6720 etc. 28800 searching adapter at COM4... adapter found, version: 2000 pins: 18, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... result: Rx:16 Tx:17 time required: 91 sec Power On ! UNLOCKED Loading boot... OK Flash ID : 017E2100 Flash type : AMD - 16 Mb ----------------------------------------------- Reading phone info ... OK ------------------------------------------------- Unlocking ... Making backup file : Reading eeprom area ... OK Saving flash ... OK Backup saved to file : LG-KP130_KP130AT_V10a_352126022004763.bkr Unlocking ... OK ====== Process completed ====== Operation time - 00:11 |
can i unlock kp 170 with multi box plz help | asif_ae | Multi-Box | 1 | 04-13-2009 07:35 |
can i unlock lg kp170 with easy unlocker plz help? | asif_ae | Easy-Unlocker | 1 | 02-23-2009 14:14 |
can i unlock lg kp170 with infinity box plz help? | asif_ae | Infinity-Box | 5 | 02-20-2009 10:52 |
How can we find 2nd cpu pinout by pinfinder | Maiwand khan | Infinity-Box | 1 | 06-06-2008 11:00 |
How can I start any prg app for Mobile ..., plz Help ... | _hosseini_ | GSM Programming & Reverse Engineering | 17 | 02-15-2008 13:07 |
