04-17-2007, 06:15 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Online Thanks Meter: 71,421 | ((((( how can i flash BIRD V10 Please Explane Step by Step )))) i want to flash BIRD V10 and i can't connect with box . my cable is ok and mobile can't power on .....can any buddy tell me here that how can i flash BIRD V10 with infinity Please EXPLAN step by step Thanks in advance Br Faisal_Computer |
04-17-2007, 09:47 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! if you 100% sure that cable is ok then this must be hardware or battery problem. please measure battery voltage ad make sure it is more than 3,7v if not charge it and try again |
04-17-2007, 16:18 | #4 (permalink) |
Member: 151871 Status: Online Thanks Meter: 71,421 | check this two pictures and tell me is that any mistake and thanks for yours reply mobile's hardware 100% ok mobile bettery 3.7 v (bettery ok) just see that pictures and tell me if any mistake . on 2nd picture when i press button for flash what i am doing see it. and one of my Freind asked me that for flashing of bird mobile you must be active yours software is it true or worng ( need to active or not need for special process for active this software ) waiting... Br Faisal_Computer |
04-17-2007, 17:25 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Hello! for flashing bird phones no any special activation required. cable picture is not quite clear for me, but from a top of my head- please try to switch places for tx and rx wires. maybe this will help |
04-17-2007, 17:43 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @Faisal_Computer Please, see picture S1180C_FlashMode.jpg in "Documentation\Infinity-Box_Bird-S1180C_S1120_V09_V10" folder for info how to prepare phone for flashing. |
04-18-2007, 06:23 | #7 (permalink) | ||
Member: 151871 Status: Online Thanks Meter: 71,421 | Quote:
my cable is ok ... my mobile's hardware in ok ... then why my infinity can't read bird V10 even its not connecting with mobile when i click on READ FLASH what should i have to do Please Help ME !! and thanks for reply Br Faisal_Computer | ||
04-18-2007, 06:57 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Dear Friend, Here is information for "Docmentation" folder, Bird-S1180C_S1120_V09_V10_important_information.txt file ========================================== Here is the steps to start Infinity-Box Bird S1180C, S1120, V09, V10 software: ==> 1. Check S1180_InfinityBox_Pinout.txt file and build cable. ==> 2. Check S1180C_HW_Identification.txt file to see the hardware difference. ==> 3. check S1180C_HW_Identification.jpg and S1180C_LCD_Type.jpg ==> 4. Check S1180C_FlashMode.jpg. You will see the buttons that have to be pressed for flashing process start. IMPORTANT !!! To avoid phone damage, please, check software version first before flashing. If your phone has new/unknown firmware, please, make BACKUP first (Read flash) and send to us. This helps you to be sure that phone will be alive in any case. ===== How to check SW version: 1. Power On phone 2. Press "*" once 3. Press side arrow down 3 (three) times 4. Press side arrow up 3 (three) times ===== Reset phone default settings/repair bugs: 1. Load FFS_Repair file 2. Flash FFS area only ========================================== what is your phone condition now ? Is it good working phone or damaged phone ? |
04-19-2007, 05:57 | #9 (permalink) |
Member: 151871 Status: Online Thanks Meter: 71,421 | bro i was readed....... just tell me that my mobile is powered on ( dead ) so how can i connect with my infinity ........ !! these all info use after when box detect BIRD V10 ... i can't detect V10 with BOX.... mobile's hardware fine , my cable is fine ..... just tell me why BOX not detecting phone ? Br Faisal_Computer |
04-19-2007, 06:45 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Dear Friend, what is your phone condition now ? Is it good working phone or damaged phone ? Is it dead or powered on ? I can't understand this from your description. |
04-19-2007, 06:51 | #11 (permalink) |
Cheater -Don't Deal with him- Join Date: Mar 2005 Age: 39
Member: 132334 Status: Offline Sonork: 100.87489 Thanks Meter: 1,193 | So u want to ask that problem in your box ??? If u think so then why not u bring your box to your reseller.He will sure tell u where is the problem. |
04-19-2007, 10:53 | #13 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Dear Faisal, I already told you several days ago via ICQ: if Bird V10 can't power-on it can be hardware problem. Also it can be that flash chip completely erased during wrong flashing (boot area erased/damaged) and in this case it's not possible to repair phone via cable ! Only need to desolder flash chip and use external flash programmer ! It's need to know detailed phone history to give you an advice what to do. Last edited by InfinitySupport; 04-19-2007 at 11:04. |
04-19-2007, 15:43 | #15 (permalink) |
Temporary banned !! Join Date: May 2005 Age: 39
Member: 148045 Status: Offline Thanks Meter: 17 | brid v10 is fully support with infinty box, repair unlock flash all you need can do in case that wrong software,may be repaired so try to flash it but if your phone cant detact or no response with box no solution for it using infinty or any tool |
Guide: How to Activate SETOOL Step by Step | shahzaadbutt | SETool2 | 66 | 06-15-2023 11:12 |
how can i flash vodafone 541....[SOLVED] | lad2 | PolarBox 3 | 3 | 03-29-2010 18:49 |
help...please explane step by step how to repair sd | CHAPRAN | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-04-2010 10:53 |
how can i change D750 to K750 please step by step | gsm4libya | Cruiser Suite | 3 | 01-07-2006 09:04 |
help please how i can use UFS-3 flasher step by step thaks | kocher | Sell ur Old and Used Stuff | 1 | 12-06-2005 19:05 |
