06-24-2010, 06:36 | #1 (permalink) |
Registered User Join Date: Sep 2008
Member: 863236 Status: Offline Thanks Meter: 4 | How Can I REmove TouchScreen Celebration |
06-24-2010, 06:54 | #2 (permalink) | |
Freak Poster Join Date: Jan 2009 Location: chennai
Member: 958595 Status: Offline Thanks Meter: 18 | Touch calib Quote:
u have infinity then go to ''repar'' press calibrate tuch button in mode -1 then mode-2 then mode-3 dont do with auto mode | |
The Following User Says Thank You to arivmoon For This Useful Post: |
06-24-2010, 07:07 | #3 (permalink) | |
No Life Poster Join Date: May 2008 Location: india / Tamil nadu
Member: 773423 Status: Offline Thanks Meter: 82 | Quote:
your problem solved or use infinity use all mode and reverce mode also if not succeed read full flash calibrate touch done | |
The Following 2 Users Say Thank You to gsm_jeevan For This Useful Post: |
06-26-2010, 03:15 | #6 (permalink) |
Insane Poster Join Date: Aug 2008
Member: 828078 Status: Offline Thanks Meter: 5 | Use infinity for do this. Please read carefully bellow. How to calibrate touchscreen: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. make full flash backup for emergency case 8. go to software "Service" page 9. select calibration "mode-1" 10. make "Reverse calibration order" un-checked 11. press "Calibrate touchscrren" button and follow instruction given by software 12. if software can not make calibration with "detection failed" error: - select other calibration mode (f.e. "mode-2", "mode-3" etc. one by one) - repeat calibration process - test phone after each "mode" try 13. if calibration process finished without errors but touchscreen can not work well: - DO NOT change calibration "mode" ! - make "Reverse calibration order" option checked - repeat calibration process again - test phone 14. if still no luck with calibration after all tries: - make full flash backup for emergency case - make "format ffs" - Power-On phone - Power-Off phone by "Power" button (do NOT remove battery) - Repeat "Calibration" operation again - if still no luck read full flash and send to support with subject: touchscreen calibration failed |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
