Old 11-23-2008, 14:17   #1 (permalink)
aamirgsm's Avatar
Member: 526737
Thanks Meter: 9
How can i solved 6300rh-37 after flash blank display...
COM4 selected
module v2.69
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: write NOR flash
skip: Firmware
skip: Customization/Language Pack
skip: Customization
write: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot enabled
chip: 0001:4F03:0004
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 01227E22202200:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.638FDBD1.[JIA6300_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V 2.BIN_E4B7E688].rpl
identification#1 detection finished
device-id: 638FDBD1
identification#1 protocol ver: 04
ver. sw 1: JIA6300_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V 2.BIN
ver. sw 2: MAUI.07A.W07.52.MP.V2, 7719481B
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: eeprom[JIA6300_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V 2.BIN]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\RH-37\eeprom[JIA6300_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V 2.BIN]_20081123-050209.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_638FDBD1_JIA6300_PCB01_GPRS_MT6225_S00.M AUI_07A_W07_52_MP_V2.BIN_E4B7E688_20081123-050224.B0X.bin
Area: Eeprom/ffs
Write: Eeprom/ffs
Write Done
Finalization ...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_638FDBD1_JIA6300_PCB01_GPRS_MT6225_S00.M AUI_07A_W07_52_MP_V2.BIN_E4B7E688_20081123-050349.B0X.bin
Finished, time used: 181 sec
Remove/Install battery now !
Loading failed, probably damaged data file
please sir help me . . . .i have1 piece chines 6300 rh-37 dead. . .
I flashed the fone difrent firmwere on the support flash is ok but display is blank. . . please tell me how can solved this problem. . .
I write the original backup but problem is same phone display is already blank. . .
Regards...
aamirgsm
Old 11-23-2008, 14:30   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
does original backup was taken from working phone?
what is it's name?
Old 11-23-2008, 14:40   #3 (permalink)
aamirgsm's Avatar
Member: 526737
Thanks Meter: 9
yes i have this given below backup file which was saved during flash:
http://rapidshare.com/files/16658834...0.B0E.bin.html
Old 11-23-2008, 14:54   #4 (permalink)
Member: 148515
hello!
we have more than 10 same version firmwares on our support site.
download some of them and flash to phone. each time after this make Format FFS complete.
i am sure this will solve your problem, if battery is full charged
Old 11-23-2008, 16:01   #5 (permalink)
aamirgsm's Avatar
Member: 526737
Thanks Meter: 9
Dear Sir,
I wrote all the firmware's which are available at teh support,
but none of them is suitable for my phone. . . and problem is still same. . .
so plz assist me now wat should i have to do to revive this phone properly. . . .
Regard's
aamirgsm
Old 11-23-2008, 16:14   #6 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,052
Originally Posted by aamirgsm View Post
Dear Sir,
Regard's
aamirgsm
try to restore this eeprom file:-
Old 11-23-2008, 17:32   #7 (permalink)
yawarniazi's Avatar
Member: 194128
Thanks Meter: 303
Here is the fully working flashfile of this mobile. I just read it from a working phone.
http://www.4shared.com/file/72801611..._MP_V2BIN.html
BEST OF LUCK!
yawarniazi
Old 11-23-2008, 19:18   #8 (permalink)
aamirgsm's Avatar
Member: 526737
Thanks Meter: 9
@yawarniazi
thanks for this contribution, i'll try to write this file
and will post the result soon. . . .
regards
aamirgsm
Old 11-23-2008, 21:11   #9 (permalink)
Member: 148515
hello guys!
when you face "blank display" problem- you must do Format FFS after each next flashing.
Not doing format- is most common mistake
Old 11-24-2008, 08:02   #10 (permalink)
aamirgsm's Avatar
Member: 526737
Thanks Meter: 9
BEST OF LUCK!
yawarniazi
Dear yawarniazi
I write the flash file after then ffs formate but problem is same. . .
Old 11-24-2008, 08:08   #11 (permalink)
aamirgsm's Avatar
Member: 526737
Thanks Meter: 9
hello guys!
Dear sir
I do formate ffs after flashing but problem is same
please tell me what should i have to do....
Old 11-24-2008, 08:41   #12 (permalink)
aamirgsm's Avatar
Member: 526737
Thanks Meter: 9
Plz sir send me video tutoiral this phone
Old 11-24-2008, 12:03   #13 (permalink)
yawarniazi's Avatar
Member: 194128
Thanks Meter: 303
Here is another working flash file of this phone. Hopefully this will help you to solve the problem
http://www.4shared.com/file/72905947..._MP_V2BIN.html
BEST OF LUCK!
yawarniazi
Old 11-24-2008, 13:03   #14 (permalink)
aamirgsm's Avatar
Member: 526737
Thanks Meter: 9
@yawarniazi
Old 11-24-2008, 14:13   #15 (permalink)
aamirgsm's Avatar
Member: 526737
Thanks Meter: 9
BEST OF LUCK!
yawarniazi
Result is same. . .
I thing it is hw problem. . .
regar's
aamirgsm
How can i solve Security Test Fail, after unlock by Mx-key powerplay83 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 9 03-25-2010 14:39
E50 after flash blank display ..::Sunil::.. HWK 38 02-21-2010 07:49
e71 after flash blank screen solved by mx key adaki_vishal MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 11-10-2009 17:09
N-gage after flash white display blank NuengEve UFS2 + UFS3-Tornadoflasher 3 02-06-2006 12:06
t722i help needed: after downgrade blank display. chris_ua Motorola P2k 3 07-16-2003 16:34
Page generated in 0.27229 seconds with 9 queries
