Old 07-20-2018, 20:29   #1 (permalink)
Member: 1814195
Thanks Meter: 17
How can i write imei on voda vfd100
Can someone help me write an imei number of vodafone VFD100
Old 07-20-2018, 20:49   #2 (permalink)
xx0o0xx1's Avatar
Member: 2033150
Thanks Meter: 624
Hi..
it seems like you are a new member to infinity box community..
well, follow this ...
open up cm2mtk v1.58
you will need to do uk off if u need to show up the imei option
u can use the dongle manger or u can do it manually by creating an empty file has this name UK.OFF inside the cm2mtk path >>>>
or simply search the forum ...
Don't hesitate request any help but first pls search the forum ..
thanks
___-----___
Devx
Old 07-20-2018, 22:04   #3 (permalink)
Member: 1677653
Thanks Meter: 2,769
Can u also help us to post log from infinity cm2?
Old 07-20-2018, 22:32   #4 (permalink)
Member: 1814195
Thanks Meter: 17
Card found : S/N :
Operation : Repair Security [ v1.58 ]
Wait for phone...
Phone found! [ 20 ]
Sync...
Device boot not done
Check Drivers
Try again
Init Service mode failed, something went wrong
Reconnect Power/Cable!
Wait for phone...
Phone found! [ 20 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : FE014E50314A39344D125DFB9E8273ED
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0xFE , OEM : 014E
[eMMC] : FLASH_INF : [MICRON] , M49J1
[eMMC] : FLASH_CID : FE014E50314A39344D125DFB9E8273ED
[eMMC] : FLASH_BRT : 0x00100000 , 0x00100000 , 0x00100000
[eMMC] : FLASH_LEN : 0x00000000E9800000
[eMMC] : FLASH_UCP : 3736 MiB [eMMC 4 GiB]
DEV RID : 0xD2874E4EF00D8250974B6D3689EBD0EC
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Burned OTP detected! Operation USELESS!
IMEI_OTP [1] :
Done!
Elapsed: 00:00:08
Old 07-21-2018, 06:10   #5 (permalink)
yuranc8's Avatar
Member: 2680008
Thanks Meter: 1,640
Hardware imei... OTP... not supported
Enviado do meu SM-J100H através do Tapatalk
Page generated in 0.14800 seconds with 9 queries
