Old 05-29-2010, 11:22   #1 (permalink)
Member: 1294926
Sonork: 100.1608183
Thanks Meter: 126
how to format this n95-8g
i am trying many way but can't format.
-ffs:safe mode
-complete mode
-nand
but still no luck
error: operation failed !
Old 05-29-2010, 11:22   #2 (permalink)
Member: 1294926
Sonork: 100.1608183
Thanks Meter: 126
COM6 [VCP0] selected
module v3.14
Action: reset settings ("format ffs")
Model: Autodetect 6205-6239 NOR
Checking data, wait...
19200 autodetect
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:323A:B7FF
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: N95_8GB.V01
Version: 8GB_06B_500
detecting structure #2...
0 done
44 byte(s) read
imei: 353xxxxxxxxxxx
connection Ok
building list...
done
items to clear: 143
items cleared: 0 of 143
items remains: 0
Finished, time used: 11 min 21 sec
Remove/Install battery now !
Old 05-30-2010, 10:19   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
what result gives format FFS complete?
Old 05-30-2010, 11:20   #4 (permalink)
Member: 1294926
Sonork: 100.1608183
Thanks Meter: 126
the same state . handset goes off with sim card
Old 05-30-2010, 12:38   #5 (permalink)
Member: 148515
hello!
can you make 112 call with SIM card removed?
Old 05-30-2010, 13:37   #6 (permalink)
Member: 1294926
Sonork: 100.1608183
Thanks Meter: 126
yes the phone works good without sim. and when calling 112 too
Old 05-31-2010, 19:16   #7 (permalink)
Member: 148515
hello!
what is phone full software version?
worth to try flashing.
but first make full backup of your existing version
Old 05-31-2010, 20:06   #8 (permalink)
Member: 1294926
Sonork: 100.1608183
Thanks Meter: 126
hello!
the soft that i found in the phone is : JIA8GB_PCB01_GPRS_MT6226_S01.N95_8GB_V01
i am trying writing other firmware and it goes to dead phone .
so i rewrite the old one and the phone goes to the first state. (goes off with sim)
i think it's hardware probleme. coz i am solving alot of this n95 same probleme. but the question is why can't do formate ffs ?
and if somone writed a wrong software before. is the infinity well give this error ?
thinks
Old 05-31-2010, 20:36   #9 (permalink)
Member: 148515
hello!
it is hard to say why it is not formating in Safe mode,
but complete mode format is even better (it clears more)
if it does not help- this is not FFS caused problem
Old 05-31-2010, 20:48   #10 (permalink)
Member: 1294926
Sonork: 100.1608183
Thanks Meter: 126
hello!
i say why it give error (not why not formating)
plz see log :
connection Ok
building list...
done
items to clear: 143
items remains: 0
Finished, time used: 11 min 18 sec
and when formating with complete mode it goes to dead phone ( i must reflach it to revive)
Old 06-01-2010, 21:41   #11 (permalink)
Member: 130995
Thanks Meter: 35,227
It looks like phone file system is seriously damaged and it can not be repaired with "safe" format.
You must use "complete" format !
If you will have any problems with "complete" format - post here operation log to check.
Old 11-30-2010, 09:15   #12 (permalink)
virgix's Avatar
Member: 69608
Thanks Meter: 63
How About this error Cannot complete format???
try using repair FFS done but phone still hang on nokia logo...
====> Boot ...
baud autodetection active
19200 autodetect
Connecting, wait...
CPU: MT6226
high speed boot Off
chip: 0031:15CE:3491
status: FF
high speed boot Off
boot packet size: 0400
Boot Done
====> Initialize ...
flash: 01227E223C2200:2CEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb
otp offset: 00000000
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
interesting cpu type found
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 2C0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 02000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [protected] type (04), 1 record(s)
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.890A831A.[N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32.B IN_F1A262E8].rpl
rom info detection finished
device-id: 890A831A
rom info ver: 04
sw version: N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32.B IN
project-id: MAUI.06B.W07.04.MP.V32, E862A2F1
code offset: 00000000
ffs offset/size [01]: 01BE0000/00420000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 01BE0000
standard ffs/eeprom offset confirmed: 01BE0000
detecting ffs/eeprom size...
ffs/eeprom size: 00420000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:01BE0000-01FFFFFF
firmware area: 00000000-01BDFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\N95_PCB01_GPRS_MT 6226_S01.MAUI_06B_W07_04_MP_V32__ffs_20101130-144328.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
error: wrong erase first sector at 0x01BE0000
error: format ffs failed
Finalization Fail
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\N 95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__s ystem_log_890A831A_F1A262E8_20101130-144338.B0X.bin
Finished, time used: 2 min 0 sec
Old 11-30-2010, 22:00   #13 (permalink)
Member: 148515
hello!
try to heat flash IC or better resolder it
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Page generated in 0.21506 seconds with 9 queries
