04-14-2009, 14:28 | #1 (permalink) |
No Life Poster Join Date: Sep 2007
Member: 582790 Status: Offline Thanks Meter: 378 | fly sl500i unlock module v2.70 Device: Fly-SL500i Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6219:8B02:8B01]... CPU: MT6219 detected CPU: MT6226MA chip: 0031:69C1DCE status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: SL900A_UKFLY_PCB01_GPRS_MT6226M_S01.SL900A_05C_W06 _08_MP_V72_F2.BIN ver. sw 2: SL900A.05C.W06.08.MP.V72.F2, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: Fly-SL500i_SL900A_UKFLY_PCB01_GPRS_MT6226M_S01.SL900A_ 05C_W06_08_MP_V72_F2__ffs... file saved: C:\Program Files\InfinityBox\MModule\Fly-SL500i_SL900A_UKFLY_PCB01_GPRS_MT6226M_S01.SL900A_ 05C_W06_08_MP_V72_F2__ffs_20090414-061458.B0E.bin flash: 89881500010001:89881500000000 Backup required data Done Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done Special operation ... detecting additional parameters... ................................. flash: 89881500010001:89881500000000 flash: 89881500010001:89881500000000 Write: area 0/1 ............................... additional parameters detected Ok Special operation Done Write ... flash: 89881500010001:89881500000000 Write: eeprom Write Done Finalization ... Finalization Done Finished, time used: 154 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to gsm-world For This Useful Post: |
04-14-2009, 19:24 | #3 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
05-01-2009, 16:49 | #4 (permalink) |
No Life Poster Join Date: Mar 2004 Location: uk Age: 54
Member: 59789 Status: Offline Thanks Meter: 16 | Here is my log SL500i COM6 [VCP0] selected module v2.70 Device: Fly-SL500i Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast Unlock procedure can be faster if you skip ffs/eeprom area backup procedure. Do you want to disable ffs/eeprom backup ? ffs/eeprom backup disabled Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6219:8B02:8B01]... CPU: MT6219 detected CPU: MT6226MA chip: 0031:6B41:E9BC status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: SL900A_UKFLY_PCB01_GPRS_MT6226M_S01.SL900A_05C_W06 _08_MP_V72.BIN ver. sw 2: SL900A.05C.W06.08.MP.V72, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 89881500010001:89881500000000 Backup required data Done Patch required data ... ................................................ lock area found Patch required data Done Special operation ... detecting additional parameters... ................................. flash: 89881500010001:89881500000000 flash: 89881500010001:89881500000000 Write: area 0/1 ............................... additional parameters detected Ok Special operation Done Write ... flash: 89881500010001:89881500000000 flash: 89881500010001:89881500000000 Write: lock-area-1 Write Done Finalization ... Finalization Done Finished, time used: 96 sec Remove/Install battery now ! |
unlocking code for fly sl500i and fly sl600! | Rebecca12345 | Phone Unlocking Codes & Maps | 1 | 06-14-2008 10:27 |
Thanks Infinity Team Fly Sl500i Unlocked | wiliam | Infinity-Box | 3 | 12-08-2007 18:44 |
I UNLOCK fly SL500i TODAY | alex12 | Infinity-Box | 2 | 10-29-2007 19:39 |
Help Fly sl500i wont unlock ? | N/East Unlocker | Infinity-Box | 8 | 09-08-2007 10:05 |
